Official F-sport Sway Bar Thread!
Old 11-08-08, 09:09 PM
love67
love67's Avatar
lol...is it really big different?...i got it intalled for 4 days now...but...i still can't feel any differents......is it just me? or something wrong?
Old 11-08-08, 09:50 PM
2slow
2slow's Avatar
I'm exaggerating a bit, but it depends how you normally drive.
Old 11-08-08, 09:53 PM
darkdream
darkdream's Avatar
Well on the IS350 it would be much more noticeable.. the f sport is 150% stiffer... much less understeer!
Old 11-09-08, 09:29 PM
2slow
2slow's Avatar
Yup. I guess not much people are installing it by themselves..
Old 11-09-08, 10:54 PM
fasteddy91
fasteddy91's Avatar
I noticed a big difference, there still is a little bit of body roll, but not as bad as it used to be. The thing I noticed most is I'm not sliding around my seat when I'm making sharp turns, getting on onramps/offramps. The car is so much more tossable and fun to drive. I do have the 350 which is 150% stiffer then before, compared to 50% stiffer for the 250.
user 6292720 (05-16-21)
Old 11-09-08, 11:36 PM
AM1
AM1's Avatar
besides what everyone else has said i also feel that the suspension overall feels stiffer, which for me is a plus. my mechanic thought i would feel nothing. haha
Old 11-10-08, 02:35 PM
RA030724
RA030724's Avatar
Originally Posted by leftyjohn
I'm going to install rear swaybar this weekend I'm suprised the bushings dont required lubrication
Do not lubrcate the new bushings that come with the bar as they are "Special high durometer dry lube impregnated rubber bushings". You do not reuse the old bushings, just the brackets. Also make sure to orient the "slit" in the bushings as shown in the instructions when mounting in the bracket. Any additional lube could negate the dry lube or cause slippage of the bushings in the brackets.
Old 11-10-08, 05:25 PM
2slow
2slow's Avatar
+1. Read the directions carefully. The new bushings have slits in them. The rear sway bar bushing slit should face the rear of the car and the front sway bar bushing slit should face the front of the car.
No need for lubrication, because they kind of come lubed already. Just alittle.
Old 11-11-08, 10:08 AM
leftyjohn
leftyjohn's Avatar
Installed rear only this weekend---15-20 mins. Can feel a difference. And thanks guys for answering my question/concern about lubing the bushings.
Old 11-25-08, 08:39 PM
t.is350.h
t.is350.h's Avatar
so from what you guys said we don't need the front sway bar? since it is 6% different? I'm trying to see if I need to get both the front and the rear or just the rear.
Old 11-29-08, 08:24 PM
fasteddy91
fasteddy91's Avatar
get the rear only, save the 200 dollars for something else
Old 12-27-08, 06:59 PM
isduong350
isduong350's Avatar
did anyone have a hard time taking off the 17mm blot for the rear? i dont want to mess up r bend the sway bar links, i tried but its not turning a bit. any tips?
Old 12-27-08, 07:53 PM
fasteddy91
fasteddy91's Avatar
Go to the gym before you start
just kidding, no problem here....remember, lefty loosy, righty tighty
Old 12-27-08, 09:20 PM
darkdream
darkdream's Avatar
are you using a torque wrench or a regular (short) wrench?
Old 12-27-08, 09:56 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
^^never use your torque wrench to break a nut or bolt loose. It's a sure way to damage the calibration.
The following 3 users liked this post by lobuxracer:
JRcanuck (10-26-22), MadMack58 (02-11-21), Yodog (02-25-23)
Quick Reply: Official F-sport Sway Bar Thread!
