replacing brake master cylinder after LS400 swap
After the LS400 brake swap i bled the brakes twice, both times after i finished, the pedal would go the floor and there was almost no braking power. So today i took it to the local shop where they bled the brakes... in the end, with the same result. after talking to them and searching around the forums, ive come to the conclusion that the brake master cylinder needs to be replaced. I've never done this before and i'm not really sure how hard it's going to be, do you guys have any input or suggestions before i try and tackle this in the driveway?
Sup bobby its Sean. Replacing the master cylinder shouldn't be that big of a deal. Just get a line wrench and take the lines off of the master cylinder. I wouldn't buy a used master cylinder from a yard or someone on here. Get a remanned one. The remanned ones come with a bleeder kit that you can use. To bleed it on the bench you might want to put it in a vice first. Put both of the bleeders on the side and tighten them both down so no fluid comes out. Then put the old brake fluid reservoir on top and fill with brake fluid. Loosen one bleeder and push on the brake piston on the back. Then tighten up so no air gets inside. Do it with the other bleeder till the air is out. once the air is out leave the bleeders on until you need to put the lines on. Take the bleeders off as quickly as possible and put the lines in. You will have to bleed the system out again. Sorry to tell you that. Have somebody help you bleed the calipers cause it is a lot quicker. PM me or call me if you need help later man.
No it is NOT the same thing. Bench bleeding is with the master brake cylinder out of the car on a bench in a vise usually and taking the air out with plastic bleeders. That is if you get a remanned master brake cylinder. Bleeding with it installed on the car would take forever! There would be a lot of air in the system if you just hooked it up without fluid and just filled it up. Either way it is best if you have 2 people doing this. Saves so much time. Do it on the bench first install it and then bleed the whole system threw the calipers. Then you should be good.
well I installed the master cylinder yesterday, took no time at all. I only bled everything through the calipers, i guess i'll have to re-do the way youre telling me, Sean, but i might need some help with that when i get back to clearwater cause i'm not sure i understand. But at the same time I installed Supra TT rears that i got ahold of as an even trade for my stock rears!!!!
Thanks
seriously dude?
i know this forum is nice and good but you cant expect to find everything lexus related on here. plus this procedure is the same for all vehicles.
google gave a few good links:
http://www.superchevy.com/technical/...nch/index.html
http://www.tegger.com/hondafaq/maste...hbleeding.html
GL
GL
SHOLEXMAN, after reading this http://www.superchevy.com/technical/...nch/index.html I now see that the variable between using a vice to bench bleed and a vehicle is that the cylinder is not level in the car so the bleed will probably not be that great.
Anyways, I think if i bleed it from the calipers a few more times and flush the whole system out, I should be ok and not have to worry about this bench bleeding process. The car stops good now, after a few more times bleeding everything i think it'll be done. I'll update when this happens
