Sway bar bolt broke.... what now?
I was replacing the bushing on my front sway bar and while tightening one of the two bolts on the passenger side of the bar... the head broke off the bolt.
The bolt is still in place and tight; however, the nut head broke off.
Can the car be driven like this for the time being? I would imagine that I can have the bolt drilled out and replace it w/ a new one I can get from Pembroke or Sewell or something. The question is, can I drive it at all? Or for a week? What could happen?
mine broke 2 weeks ago while installing my coilovers, havent looked under there since to see what happened, it just makes noise everytime i hit a bump.. havent had time to replace it.
yeah im going through the same thing... i was putting on some supra tt shocks/springs and it makes the pestering noise.... just dont drive crazy. find a replacement though
you should be able to drive around but i'd get it fixed asap. i had this problem on my hachi for the longest time and all it did was make a noise on bumps and the car didnt handle as flat in the turns
happened when i did mine as well. just take the mount off of the body of the car and take the bolt out, should be able to just with your fingers at this time since there is no strain on it. if this isn't clear enough, let me know and i'll try to find some pictures of it to explain better.
you might be able to get the bolt out of the top of the mount as well without taking the mount off the car (i.e. opposite side of the bracket, sway bar, and bushing)
