sever rear tire wear on inside?? 1 side only
ok my pass side rear just ate thru a 300 dolllar tire in 8,000 miles??
somethings a miss, what do i need to check allignment? its only on the inside fist 1 to 2 inches the rest of the tire still looks new....also started hearing a slight noise like very light knocking as you drive over bumps
stock struts w/ eibach springs
drivers side is ok..........im pissed....anyhelp out there
ill take it to the local shop and put it on a lift...somethings gotta be jacked up.......just wondering if this has happened to anyone else and what it was so i can eliminate the problem asap
Interestingly, I'm on stock 16's with some Goodyear action - but mine did the EXACT same thing in the same place on the same tire.... The difference for me was that I got about 25 thousands miles out of it before it got to that point.
But all the same - it still wore out in the same way on the same tire - what gives I wonder?
My car is a stock 1993 SC 400
It's called flipping - look into it
It's sad only in that it was totally avoidable if the tire wear had been monitored and the tire was flipped at the right time to even out the wear as much as possible. Even with alignment within specs, many of us (and not just SCs) have this same inner wear problem on all 4 wheels, so you gotta flip if you want the most wear out of your tires.
I've done this on my past two sets of tires. Tito at Atlantic Tire on Fairfax (for those of you in LA, he's at 323.654.0814) flipped all 4 of my 16" tires for only $40, and I got thousands more miles of life out of my tires. You can see in the pic below that I waited a bit too long for that particular tire, but I wanted to get all 4 flips over with at the same time.
For the tire shown above, it looks like flipping at any point in the life of the tire would have helped out, but usually it's best to flip at the correct "halfway" point so that tire life is maximized, i.e.: both edges wear down to the 2/32" T.W.I.'s at the same time.
(On most tires, the last 2/32" of tread depth is not usable. And most new tires start with 10/32" or 11/32" of tread depth. So you are usually working with 8/32" or 9/32" of tread that wears over the life of the tire.)
As I explained in the following thread:
https://www.clublexus.com/forums/sho...d.php?t=185290
... the optimal time to flip is when the sum of:
the usable tread left on the inside edge
+ the usable tread left on the outside edge
equals the total usable tread the tire had when new
If you flip it before that point, the original outside edge (which ends up being inside) will wear out before the rest of the tire.
And if you flip it after that point, the original inside edge (which ends up being outside) will wear out before the rest of the tire.
But if you use the summation method, both edges of the tire will wear out at the same time.
