Brake Master Cylinder upgrade?
Old 04-20-08, 07:04 PM
dejacky
dejacky's Avatar
Question Brake Master Cylinder upgrade?
Does an upgraded brake master cylinder exist for our SC cars? I have the LS400 front brakes but I hate the initial dead-room when pressing the pedal. I don't like the fact I have to push farther down the brake stroke to get the front brakes to engage. It makes them feel like more of an on/off switch than smooth braking progression. Even though the brakes stop my SC MUCH better than stock brakes, I would like to change this breaking feel. Does an upgraded brake master cylinder exist for our cars?
Old 04-20-08, 10:11 PM
5sp_jzz30
5sp_jzz30's Avatar
if you get the supra tt brake booster and master cylinder it will most likely bolt. in. the sc changed the master cylinder. not sure of a year. i have a 93 sc300 and my original master cylinder was held in place by 3 bolts. i got a master cylinder out of a 95 sc300 and and that one was attached by only 2 bolts to the brake booster so i had to switch out both(i got both dirt cheap so i didnt mind). theoretically the supra tt master cylinder should bolt right up.
i just checked supra forums and the 95 NA supra master cylinder is held on to the brake booster via two bolts. i dont know if the tt and NA master cylinders are the same. the easiest way to check is to have someone cross-reference the part numbers for the NA and TT supras.
from what i have seen so far the NA supra have a 2 bolt master cylinder.
Old 04-20-08, 11:03 PM
dejacky
dejacky's Avatar
Thumbs down
different bolt pattern
Old 04-21-08, 12:06 AM
Black_SC
Black_SC's Avatar
i was wondering the same thing.....i hate that dead space too.
Old 04-22-08, 12:51 AM
ihiryu
ihiryu's Avatar
dang, i've been wondering about the BMC too...
Old 04-26-08, 07:07 PM
Fireblaze
Fireblaze's Avatar
Basically what Jzz30 was saying: You can't bolt up the 3 bolt supra TT cylinder to the SC 2 bolt platform. The way to do this, is to fabricate a flange adapter.
Old 04-29-08, 05:00 AM
dejacky
dejacky's Avatar
Question
how about a pic of something similar from another car?
Old 05-18-08, 10:02 AM
ihiryu
ihiryu's Avatar
sorry to bring back a dead thread, but does someone have a picture of one from a LS400?? Or maybe a GS400??
Old 08-04-08, 03:11 AM
wanganstyl
wanganstyl's Avatar
some of the earlier LS400 have 3 bolt flange MC and similar hose outputs- anyone ever try swapping onto a SC?
Old 08-04-08, 08:05 AM
Kohinoor
Kohinoor's Avatar
are there any aftermarket mc's that would work?
Old 03-21-09, 04:21 PM
RyanV
RyanV's Avatar
I have bigtime dead space after upgrading to all 4 TT calipers.
When I depress the pedal I dont stop until way down near the floor...kinda freaky.
I tried a TT brake master today, and it is the same thing.
I'm now wondering if the TT brake booster is required in order to get really good pedal feel??
The TT booster is smaller though and the brake lines dont line up and it doesn't seem like it fits the pedal bracket correctly to me.
I tried this today...
Old 03-21-09, 05:04 PM
RyanV
RyanV's Avatar
TT booster is on the left. Notice the rear shaft is longer..I wonder if this could be shimmed with washers????
http://img.villagephotos.com/p/2003-...2/IMGP2437.JPG
Old 03-21-09, 07:38 PM
5sp_jzz30
5sp_jzz30's Avatar
you have a serious brake problem with your car. there is no way in hell that you should only have brakes at the floor even if you are on a wrong master cylinder. look into a master cylinder rebuild kit or someone that know how to properly bleed brakes. not saying that you dont but if you couldnt do it maybe you should have someone else do it.
btw the order of bleeding for our cars in the not the same as the standard car. the ABS unit is on the passenger side and the RF is the shortest line not the FL. so the order is. RR, LR, FL, FR
good luck.
Old 03-23-09, 11:27 AM
JohnEd
JohnEd's Avatar
Dejacky,
Unless you had this same problem BEFORE you installed the LS brakes, your problem is not with the master cylinder. Read the other recent posts about the BBK swap and LS 400 UpGRADE that are up right now. That info willsave you a ton of work and time and money. Really!
You have been a big help to me in the past and it is nice tobe able to maybe return some of that favor.
John
Old 04-01-09, 07:22 PM
JakeBreyck
JakeBreyck's Avatar
you could always just use one of these.
Quick Reply: Brake Master Cylinder upgrade?
