Brake Master Cylinder upgrade?
Old 04-30-09, 02:03 PM
RyanV
RyanV's Avatar
I fixed my brakes. For one thing I had the rear calipers on the wrong sides of the car. The bleeders need to be at the top when the calipers are installed.
Once I swapped them, I suck out a bunch of air with the Mityvac before the fluid hit.
I also put worm gear clamps on the brake booster.
Now, I have a firm pedal.
Old 04-30-09, 02:35 PM
YeA 2jZ
YeA 2jZ's Avatar
Originally Posted by RyanV
I fixed my brakes.
can you explain this more any pics ????
Old 04-30-09, 07:49 PM
RyanV
RyanV's Avatar
The big vacuum line that comes out of the brake booster, it has 4 clamps on it. I replaced those 4 clamps with worm gear style clamps(the one you can tighten with a ratchet or screwdriver)
http://img.villagephotos.com/p/2003-...2/IMGP2468.JPG
The thing that fixed my brakes was swapping the rear calipers to the correct side of the car, and then bleeding the air out of the brakes.
Old 05-01-09, 08:04 AM
YeA 2jZ
YeA 2jZ's Avatar
alright and by using these gear clamps you just tighten extra tight to get a good vac seal i asume, do you think this helpd your pedal feel or was it the fact that your rear calipers where backwards?
Old 05-08-09, 05:39 PM
RyanV
RyanV's Avatar
I think it was probably more that the calipers were on the incorrect side of the car at this point.
Old 03-12-15, 11:55 AM
acylon
acylon's Avatar
Default Useless thread...
I have a 1995 SC300
I installed Supra TT Calipers and Rotors.
SC300 has a three bolt master cylinder.
Supra has 2 bolt master cylinder.
Supra brake booster has too long of shaft to the pedal. ~1"
-I cant find any info on this problem-
Old 03-12-15, 05:27 PM
BiGEZ
BiGEZ's Avatar
The SC went to the 2 bolt design on the brake booster from 96. I also did the LS400 brake swap and had the dead pedal feel. I recently installed supra TT rear calipers and stop tech stainless steel braided lines. The car stops impressively now, no more dead pedal feel.
I recommend the TT calipers if you can find some, however the braided steel lines should also make a difference with the dead pedal feel when using the LS400 calipers..
evileagle
Suspension and Brakes
06-06-10 08:37 PM
lisc300
11-12-09 05:29 AM
want sc300
12-20-08 10:39 PM
sxylxy
12-05-06 08:34 AM
Quick Reply: Brake Master Cylinder upgrade?
