Ball Joints HELP!!!
Old 04-05-08, 04:31 PM
Vic184
Vic184's Avatar
Default Ball Joints HELP!!!
hey guys i own a 1999 GS400 and the other day i was driving home from work and as i get off the highway BOOMMM!!! my balljoints pop and there goes my wheel at a 90 degree angle.
i got the balljoints fixed and then got a wheel alingment that i needed anyways.
now here is my problem:
my abs vsc and vsc off lights are on in my dash!!
my mechanic checked it out but he doesnt know which are the sensors that have to be replaced. i researched around but couldnt find a straight up answer on which piece is it that has to be replaced
CAN ANYBODY HELP ME PLEASE!!!!
Old 04-05-08, 05:00 PM
Spyder78
Spyder78's Avatar
you broke the cables search for jefftsai's diy on how to repair the cables.
Old 04-05-08, 05:08 PM
GSteg
GSteg's Avatar
Well you have one in the front right and one front left. Could be one, or both
If you have a multimeter at home, measure the resistance of the speed sensor. The connector is located behind the fender liner. Just pull the plug out and read the resistance. It should be 1.4k-1.8k Ohms. If not, then it's broken. If it falls within the range, then the sensor is good so go try it on the other side.
Old 04-05-08, 05:10 PM
GSteg
GSteg's Avatar
Hell....if the shop is paying for a new sensor(s), might as well get him to buy new ones
Old 04-05-08, 08:21 PM
Vic184
Vic184's Avatar
i have found this DIY but now i am just wondering how do i remove the cable so i can do this at home since i do not have a garage?
heres a link to his DIY if anyone could help me out let me know please i really appreciate it
http://www.projectgs.com/DIY/SuspBrake/ABSVSC/index.htm
Old 04-06-08, 08:26 AM
cm0nkey
cm0nkey's Avatar
Here is my diy on that:
http://www.chrisandnat.com/projects/.../SensorFix.htm
http://www.chrisandnat.com/projects/.../BallJoint.htm
Old 04-08-08, 09:42 PM
Vic184
Vic184's Avatar
bump anyone else with info it will be greatly appreciated
Old 04-12-08, 02:39 PM
Vic184
Vic184's Avatar
Guys thanks alot for all your help and advise i used the 2 diy and it was tremendous help. between me and my cousin we took the sensor off and fixed it and now its back to new!!!! total cost- $24.95 Dealer- $200 talk about a steal !! thanks again guys
Old 04-12-08, 05:14 PM
MJImport
MJImport's Avatar
Congrats! It always feels good to repair something yourself, not to mention the cost savings! btw, did you observe any warning signs prior to your ball joint failing?
Old 04-12-08, 05:41 PM
GsCruiser
GsCruiser's Avatar
any symptoms before it went out..how many miles do you have on your ride.?
Old 04-14-08, 10:30 PM
Vic184
Vic184's Avatar
i have 92k miles on the car and i did have alot of symptoms before they went out. i was actually on my way to move the car into the parking lot across the street from my mechanic so he could fix it the next morning when my ball joints popped.
some of the symptoms i had where hearing strange popping noises coming from the front . like if something was popping out of place. you can also check them out by putting your car up on a lift and lifting ur tires up and if theres alot of movement then you know something is wrong and you need to change them ( i was told this by mechanic so do not hold me to this)
RADTCB
Suspension and Brakes
12
01-02-17 01:28 PM
98cruiser
11-21-09 05:17 PM
cpxdamon
09-10-08 07:35 AM
daintyboy
01-08-08 09:41 PM
400 Degrez
01-06-07 06:21 AM
Quick Reply: Ball Joints HELP!!!
