do all is250 and is350 both have stock big oem calipers ?
Old 04-02-08, 10:41 AM
mikemareen
mikemareen's Avatar
Default do all is250 and is350 both have stock big oem calipers ?
which models come with the oem big brake calipers ? thanks
Old 04-02-08, 10:45 AM
radicalrev
radicalrev's Avatar
IS350 has bigger calipers...need R disk wheels to clear at the front...
Old 04-02-08, 01:34 PM
projectdna
projectdna's Avatar
is350 has big oem calipers. 4-pots up front, iirc.
Old 04-02-08, 02:11 PM
Brian231
Brian231's Avatar
350 pads can also be replaced from the top of the front caliper by removing the cross pins. The 250 requires removing the caliper which is not a big deal.
Old 04-02-08, 03:15 PM
radicalrev
radicalrev's Avatar
Does Medium Disk wheels clears the IS350 brakes? Or do you ONLY need to use High Disk?
Old 04-02-08, 03:17 PM
llamaboiz
llamaboiz's Avatar
You need the R disk or High disk, each brand has a diff name but R and High are most common for the high end rim companies. IF not you'll have to run spacers.
Phamkq
10-04-17 09:39 PM
ULTiMaX99
11-07-15 02:21 AM
jyeung12
Suspension and Brakes
15
08-06-14 10:03 AM
hotwheels1
02-15-11 02:30 PM
Quick Reply: do all is250 and is350 both have stock big oem calipers ?
