Driver's Side Wheel Noise.
Guys,
I have an Issue with my GS3!Recently I hit a Bump and my Driver's Side Wheel started making this Squeaking Noise/Chunk when I Turn the Wheel from Left to right.I also hear a Noise whenever I hit any Bump,I was thinking it's my Strut.I took it to a Mechanic and they both said it wasn't my Ball Joints and that it maybe a Bushing that needs to be Replaced but when one Mechanic put it on a Lift and then put a Hand Lift(?)somewhere around the Drivers wheel,the Noise didnt happen.Matter fact they inspected it and while they were touching around the Balljoints etc the Noise almost went away completely.The Mechanic said that I had to bring the Car back if it makes the Noise again.So I told a Buddy of mine about the Issue and he said spray a Lube allover the Bushings and it should work and get rid of the Noise since the Mechanic touched some of the Bushings and probably got Grease back into the Bushings.So I drenched the Bushings and Joints and also Sprayed the Struts and it seems to do the Job.Well today the Noise is back in full Force and is very annoying.Anyone have any clue to what the problem might be?
