Daizen LCA Bushings on 98 GS400
Old 10-14-07, 07:49 AM
kswagner
kswagner's Avatar
Default Daizen LCA Bushings on 98 GS400
Is this a DIY job? Ive seen some DIY tutorials for the LS - is the GS400
pretty much the same? Im somewhat mechanical and have done the lower ball joints and outer tie rods on my GS400. I do have an arbor press available but have seen in some DIY tutorials that people use a big C Clamp....I also believe my caster arm bushings are shot - are those easy to replace? Any other recommendations about parts I should replace while Ive got the front end broken down would be greatly appreciated. Car has 132K on it.
Thanks in advance
Old 10-18-07, 06:36 PM
kswagner
kswagner's Avatar
Nuthin guys????? Nobody has done this...
Old 10-18-07, 07:17 PM
GSteg
GSteg's Avatar
It's a DIY job if you have lots of time on your hand. It's nothing that requires a mechanic engineering degree. The tough part is probably taking out the metal sleeve of the caster arm, and pressing in the daizen caster bushing without damaging it.
Old 10-19-07, 02:22 AM
marshun
marshun's Avatar
i've done ALL the bushings on my cars. well except the GS since i just got it. but anywho. taking out the old one is the hardest part. burn out the old with a torch, cut the sleeve with a hack saw, dremel the inside smooth (the hacksaw will slightly shred the hole up) then grease it up. use a long bolt with big thick washers to push in the new bushing. so its like a vice and you just squeeze in the new one by tightening up the bolt. wallah! easy as hell. maybe, if i remember, i'll make a DIY when i do the GS
lyonkster
Suspension and Brakes
288
04-24-23 03:18 PM
Lexicious
10-03-13 12:19 PM
lyonkster
12-09-10 01:53 PM
magnetik
12-29-09 04:05 PM
Quick Reply: Daizen LCA Bushings on 98 GS400
