Daizen Bushings damaged upon install
Old 08-16-07, 02:54 PM
Eric00GS3
Eric00GS3's Avatar
Default Daizen Bushings damaged upon install
I took my Castor arms to the shop guy to get the old bushings removed and Daizen bushings pressed in. The removal went just fine. But then when he pressed the Daizens in, the lip on the side of the bushing that entered the hole was partially cut off on the first bushing and just slightly cut off on the second bushing. He claims that he used plenty of grease and pressed them in evenly. I’m not convinced, but the bushings are already in and there’s not much I can do at this point. He assured me they wouldn’t go anywhere and would be fine to drive on. I checked them out and they do seem pretty solid.
Do you think they are safe enough to drive on?
Will they provide a solid ride?
See pictures below.
Old 08-16-07, 03:07 PM
Kbueno
Kbueno's Avatar
Hard to say unless we can see where they are cut. Only time will tell...if they are cut bad you will develop noises. I heard the pressing is difficult, that's why I had TM Engineering install mine.
Old 08-16-07, 04:13 PM
Eric00GS3
Eric00GS3's Avatar
Yeah, the shop mechanic said he had done many Daizen installs on GSs. But as you can see in these pictures, he's full of it or there are a bunch of others out there with damaged castor bushings.
Attached Thumbnails Daizen Bushings damaged upon install-photo_081607_001.jpg
Old 08-16-07, 04:14 PM
Eric00GS3
Eric00GS3's Avatar
Picture 2........
Attached Thumbnails Daizen Bushings damaged upon install-photo_081607_002.jpg
Old 08-16-07, 04:15 PM
Eric00GS3
Eric00GS3's Avatar
Picture 3.........
Attached Thumbnails Daizen Bushings damaged upon install-photo_081607_003.jpg
Old 08-16-07, 04:16 PM
Eric00GS3
Eric00GS3's Avatar
Picture 4.........
Attached Thumbnails Daizen Bushings damaged upon install-photo_081607_004.jpg
Old 08-16-07, 04:17 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Thats the new one...
Old 08-16-07, 05:44 PM
LEXTEK444
LEXTEK444's Avatar
He can say all he wants that bushing was put in crooked. If it would have been even the crack in the side would be even. He probably got them half way in, realized they were going in crooked, and readjusted the press. Sorry to hear about the bad luck.
Old 08-16-07, 10:49 PM
Eric00GS3
Eric00GS3's Avatar
Yeah it sucks. So do you guys think it is safe to drive on them?
Old 08-17-07, 07:29 AM
lexforlife
lexforlife's Avatar
eric
hate to be the bearer of bad news but those bushings will fail extremely fast , the integrity of the bushing as a whole has now been compromised .. i would bet that inside the bushing is also torn and will tear apart
these have to be pressed in perfectly straight and slowly from the smooth side , was the edges of the arm smoothed out and rolled prior to pressing in for if not this is what happens , it gets cut on the edge
you have to grind the edge a tad then sand smooth so bushing slides in with no resistance
contact todd at tm engineering he might can sell you just the castor bushing ,
Old 08-17-07, 07:44 AM
Eric00GS3
Eric00GS3's Avatar
Thanks Lexforlife for the input. I asked him if he sanded the edges down and he said he didn't because if he did then the bushing would not be secure inside the arm. Obviously not a bushing expert.
Old 08-17-07, 11:15 PM
lexus75
lexus75's Avatar
cracks and tear is why you replace them in the first place.have him get you new ones
RMMGS4
53
12-19-05 08:53 AM
VehicularL
Suspension and Brakes
11-16-04 09:12 PM
Quick Reply: Daizen Bushings damaged upon install
