Is there a diy for changing front calipers?
Old 08-09-07, 08:05 AM
kmaynard
kmaynard's Avatar
Default Is there a diy for changing front calipers?
I may have damaged a line or ring changing my pads the other day, there was a spot on my drive this morning. I didn't have time to investigate before leaving for work, it didn't look too bad to drive, but definitely a seepage of some sort.
I'm hoping it's not but fearing it is my caliper, although I tried to be careful when clamping my pistons.
If it is, is there a diy out there, thinking maybe I can rebuild the caliper without getting a new one, replace all the rings . . . so I guess either a diy to replace the caliper, or a diy to rebuild/reinstall, either way.
If not, going to the shop tomorrow morning . . .
Thanks.
Old 08-09-07, 08:30 AM
Spyder78
Spyder78's Avatar
My caliper broke last week and I search for the rebuild kit and I couldn't find any best thing to do is buy a remanufactured caliper and call it a day.
Old 08-10-07, 06:10 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
COntact jeffTsai or bananaGS's websites..
Old 08-10-07, 09:47 AM
kmaynard
kmaynard's Avatar
Ok, this thread could be closed, I guess. The spot wasn't there at the end of the day, and later that night I checked and it was still dry all up around the brake and wheel. Had new tires put on (from Tirerack, same place I got my brake pads) at a local shop, and they checked it too, didn't see any problems. Spot on drive must have been from where I changed the pads, and didn't pay attention to what I dripped while working on it.
Learned a lot, though, may be able to actually change it out if I had too.
Thanks for the links and info.
Eminence
IS F (2008-2014)
09-27-16 05:47 PM
LACSTER
CT 200h Model (2011-2017)
24
06-27-15 10:56 AM
CProffitt
04-13-13 07:51 PM
Coleycole
NELOC
09-22-12 12:47 AM
BDiccus
Suspension and Brakes
03-14-06 09:14 PM
Quick Reply: Is there a diy for changing front calipers?
