Old 01-07-15, 12:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
DIY Lower Ball Joints for the 2nd Gen GS. - Step by Step Instructions and Pictures
Old 06-05-13, 06:28 PM
  #136
ohboitony
ohboitony's Avatar
Originally Posted by boosteddsm
I must have been doing something wrong then, this didn't work for either side, ball joint or tie rod. Ended up using pickle forks, worked great, didn't care about the boots/joints since I was putting all new ones on anyway.
Same here!!! I bang the living crap on it and it never came loose. So I used a fork and two hits it was loose. Only took two hours to do both side not bad at all.
Old 06-08-13, 05:28 PM
  #137
ajsgs400
ajsgs400's Avatar
Default ball joints
Thanks for all the info, had my ball joints checked was told they were bad. lexus quoted $980.00 and need my gs400 all day. I did it myself in a hour and half. Thanks again for all the info
Old 06-08-13, 05:31 PM
  #138
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
make sure you get a alignment... Wow that is ridiculous quote from Lexus...
Old 06-08-13, 06:52 PM
  #139
Blanco
Blanco's Avatar
Like a boss!!
Old 10-07-13, 10:36 PM
  #140
I3lackout
I3lackout's Avatar
Great write up. Had my lower fall apart on me (Just got the car a week before and saw the ball joints oozing grease, just hadn't fixed it yet. Luckily it was as I was pulling out of a parking spot so I didn't damage anything except the ABS/VSC sensor. Thanks for referencing hardware sizes, saved me a ton of trouble.
Old 02-09-14, 08:12 PM
  #141
Asands
Asands's Avatar
So appreciate seeing your post on lower ball joint removal, I have never done anything like this and the shop wanted Huge money to do it. Where did you order your parts from? I have a 98 GS400 with 105K ,Love the car !
Old 02-09-14, 09:03 PM
  #142
tmf2004
tmf2004's Avatar
This is a great thread for you from one of our newest members.. Just about everything you need for a front end refresh with part numbers and with 105k your due for most of these items...
https://www.clublexus.com/forums/sus...front-end.html
Old 03-05-14, 09:27 AM
  #143
youngs3oo
youngs3oo's Avatar
Default VSC, ABS, VSC off lights...
So after throwing on my Moog ball joints i got this...any ideas as to why?
Attached Thumbnails DIY Lower Ball Joints for the 2nd Gen GS. - Step by Step Instructions and Pictures-photo.jpg
Old 03-05-14, 09:29 AM
  #144
tmf2004
tmf2004's Avatar
you probably did something to the abs sensor when installing the ball joints
Old 03-06-14, 08:44 AM
  #145
youngs3oo
youngs3oo's Avatar
Yeah I tried to put the calipers on some blocks so that they wouldn't hang from the brake line but they did slip at one point. Any way to fix this?
Old 03-07-14, 01:33 PM
  #146
egs21
egs21's Avatar
Hey guys, I'm looking at getting the ball joints replaced on my GS as a pre-caution. Did any of you have to replace upper control arms? Sounds like that is the pricey part of the fix and I'm wondering if I need to worry about that.
Thanks.
Old 03-07-14, 04:05 PM
  #147
youngs3oo
youngs3oo's Avatar
^^Not sure about the control arms but a lot of members also replace the tie rods while they''re at it. It's fairly cheap too if you get it from Rockauto.com.
Old 03-07-14, 04:14 PM
  #148
tmf2004
tmf2004's Avatar
yea since your there you might as well do the tie rods, and upper control arms. I'm sure the upper and lower ball joints are pretty loose.
Old 03-24-14, 11:10 AM
  #149
GRANYZ400
GRANYZ400's Avatar
This thread is awesome, thanks so much! I see mention and one posted video of how to "hit" tie rods and ball joints out, but I did not see a video specifically for Lexus.
I tackled the LBJ's this past weekend. For those of you that cannot get your LBJ off using the hammer method, I took a quick video to specifically show how I did it. 1998 GS400 with 118K miles. Pull up on it and keep hitting it. It will go - trust me. As for the tie rod, I just used a pitman arm remover because it was sitting there. I was too scared to bang on that one, but I really just should have done it.
Old 05-05-14, 01:55 PM
  #150
tmf2004
tmf2004's Avatar
rock auto for all your suspension needs is a good place to start. please read other posts on what brands to buy. thanks
Quick Reply: DIY Lower Ball Joints for the 2nd Gen GS. - Step by Step Instructions and Pictures
