Upgrade brake question
I listened to a rep from Bilstein last night of a local talk radio show and he mentioned that many people are increasing their wheel size without doing anything to their stock brake setup. He stated that when you increase your wheel size you should also take into consideration increase your car’s braking capabilities. I was wondering those of us who want to go from a stock 16 or 17 wheel to a 18, do we need to get a better braking setup? What about 19, 20 etc. Can anyone comment on this or should I move this the the brake forum?
Thanks in advance.
Thanks in advance.
Since you are USUALLY increasing the total weight of the car when you increase wheel size, aftermarket calipers and other brake parts should be considered. Going from 16/17 to 18 is not too big of a deal, but when you increase the size of the wheel by more than that without upgrading your braking system, you increase your stopping time and stopping distance - neither of which is desireable.
Again thanks.
Thanks
Thanks Mods for the help with the move.
No Problem, you might also want to beef up your suspension as well. I am pretty sure you will be putting more stress on such components as the ball joints and tie rods as well. You don't want those failing on you. Just a thought.
What are some "good" tires. Also with 20's, would you consider slotted Rotora's and Rotora SS lines as an upgrade? Or is the only real brake upgraded beefy calipers?
Just got back from the Tire shop discussing this very topic. The guy was very high on Michellin PS2s. I pressed him on Toyo Proxies, which he also spoke well of. He made a good point that its not just an issue of grip, but also ride quality and noise as the tires wear. He was ribbing me about my Goodyear Eagle F1-GSD3s. I do so love the grip of the F1s, but man so noisy when they're worn out. Only tire I think is worse for noise were my Bridgestone S03 Pole Positions.
The factory GS brakes are very very good as long as your pads are not worn. No need upgrade them just because of a wheel size increase unless you want to for looks. If you take your car on a road racing track then you might want to look at a Big Brake Kit.
I was never a fan of Goodyear tires. I always laugh when my dad said "Goodyear can't make a round tire"
Guest
Posts: n/a
Cheaper tires simply do not provide the same grip in corners, thus if you brake very hard, they won't grip the road as well to stop the car.
Slotted Rotora's and SS lines are a brake upgrade but did you change the pads?
You start with Pads, they are the first and usually can help with most braking situations.
BBKs do not shorten stop distances. What they do is eliminate fade, so your 100th stop is as good as the 1st one. With stock brakes, they simply cannot dissipate the heat in time.
Guest
Posts: n/a
