2-pc Racingbrake oem sport rotors
Old 05-17-07, 03:17 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Default 2-pc Racingbrake oem sport rotors
Has anyone ever heard of these rotors? They list for about $340/pair. I only saw like 2 threads on all of CL on these. Has anyone here used them or heard of them?
Old 05-17-07, 10:04 PM
GSing430
GSing430's Avatar
no, but i've seen the dba, assuming you're using the supra bbk
http://www.tirerack.com/brakes/brake...+2-Piece+Rotor
Old 05-18-07, 05:27 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Hey,
The dba ones you mentioned don't look like you need a BBK for them...I know that you don't need a BBK for these Racingbrake 2-pc rotors; they are OEM direct replacements.
check out this website (copy and paste up to your address bar)
http://www.racingbrake.com/GS_300_FR...p/2051-311.htm
I was going to go with Brembos again but came across these and now I'm thinking of trying these out. The shipping weight of the Brembo cross drilled OR slotted rotors (front pair) is 35lbs = 17.5lbs/rotor. These lightweight 2-pc Racingbrake slotted rotors are 14.9lbs/rotor! Can a savings of 2.6lbs of unsprung weight on each corner really help with performance (both braking and acceleration)?
Old 05-19-07, 05:25 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Revised...$286 for the pair of front slotted. I can't believe no one used or ever heard of these. I mean come on, all you guys that don't have BBK's why would you opt for a Rotora, Brembo or iRotor drilled/slotted/blanks when you can have something do the exact same thing but weighing less (less unsprung weight)! Is there something that I should know about the QUALITY of these Racingbrake rotors? or is it just that many here haven't had experience with them?
Old 05-19-07, 06:08 AM
GSing430
GSing430's Avatar
i believe they are $286 each or $572/ pair
Old 05-19-07, 08:36 AM
Rock-a-Lex
Rock-a-Lex's Avatar
Oh crap! I'll probably still get them anyway. What type of pad would you suggest for these rotors? I know the better stopping performance pads are more "aggressive" on the rotors and wind up wearing them down for life of just 1 pad; I don't want that especially if I'm going to buy expensive rotors like these. Please suggest something that can provide me good stopping power and not be too harsh on my rotors. I've used Axxis Metal Masters before and they were OK but I think they ate my rotors up too.
Old 05-19-07, 09:02 AM
GSing430
GSing430's Avatar
try akebono, last a long time, no brake dust and stop noticeablily better than oem. there 2 verson, get the high perf. one.
Old 05-19-07, 12:40 PM
Rock-a-Lex
Rock-a-Lex's Avatar
thanks...I'll check it out.
Old 05-19-07, 12:49 PM
natnut
natnut's Avatar
I have these 2 piece rotors.So far I've no problems with them
Not only are they unsprung weight, they are rotational weight savings so there's even more of a multiplied effect then lightweight calipers which don't rotate/move with the wheel.
You may not feel the "seat-of-the-pants" effect but rest assured there is a significant difference.
bigblack06
02-08-12 12:29 AM
BADFNZ
Suspension and Brakes
19
05-01-10 06:36 PM
LexFather
06-15-08 02:25 AM
chuckb
02-22-07 06:30 AM
BlkOnBlkGS
01-16-05 11:57 PM
Quick Reply: 2-pc Racingbrake oem sport rotors
