Has anyone used Just Brakes??
Old 05-13-07, 06:32 PM
GriffLex
GriffLex's Avatar
Default Has anyone used Just Brakes??
I know, I know, I shouldn't even be thinking about taking my 01 GS430 for replacement brakes to anywhere other than a dealership (which is crazy) or a certified Lexus repair shop, but has anyone used Just Brakes?? I hear their commercials all the time, but for $100 for all 4 wheels replaced seems real cheap. Also, I was noticing some issues with them from former customers.
Let me know your thoughts. Maybe someone has used them with no problems. But, right now, I am probably going to go back to the certified Lexus shop where I had previous service done with no issues.
Thanks...
Old 05-13-07, 08:13 PM
salimshah
salimshah's Avatar
Is there something wrong with the brakes or simply worn pads?
Most of the shops are too agressive and do much more than just put the new pads.
I have no experience with Just Brakes.
Salim
Old 05-14-07, 09:55 AM
GriffLex
GriffLex's Avatar
Basically, the Lexus shop told me the pads are worn and of course, the roter's need to be re-surfaced, otherwise, that's the only problems. And this is just on the back, but I figured to get all 4 done.
Old 05-14-07, 10:01 AM
Aristo300
Aristo300's Avatar
If your rears are worn, there is a good chance the fronts are shot.
Old 05-14-07, 10:50 AM
speedaddic
speedaddic's Avatar
DO NOT GO TO JUST BRAKES. Their objective is to get you in there and to ring up as much crap as they can. Do not go there!!!! Rip off artists
Old 05-14-07, 12:26 PM
salimshah
salimshah's Avatar
If pads are worn and caught in time, they do not need the rotors to be turned. If you are not getting pulsation sensation when you brake, and there are no pits/grooves on both sides of the rotors ... do not trun the rotors.
Since I check and repalce my pads before they cause damage, I have never had the need to turn the rotors. It takes me more time to jack all ends and remove the wheels and reinstall them, then to replace the pads.
Salim.
Old 05-14-07, 01:03 PM
tuddy
Negative Nancy
tuddy's Avatar
You get what you pay for
Old 05-14-07, 01:04 PM
LEXUS_KID
LEXUS_KID's Avatar
You get what you pay for.....
Old 05-14-07, 01:07 PM
mole
mole's Avatar
and
I think you answered your own question here
Old 05-14-07, 07:54 PM
toeb
toeb's Avatar
i own a shop and charge a 100 just to do a complete front brake job. to do both ends runs bout 160 unless the rear is a drum then its more $.
Old 05-14-07, 08:31 PM
jriggs
jriggs's Avatar
bingo i agree, i took the 528i i use to have in once and they "forgot" to tighten down the bolts on my front driver side wheel after i had my rotors turned, i ended up having to replace all the studs, and they refused to accept the blame i could have gotten lawyers involved and such but its was a lot easier to just replace the studs and call it done.
Old 05-15-07, 09:49 AM
sockfocks
sockfocks's Avatar
i would do them myself its not that hard...
Old 05-31-07, 12:59 AM
herc8000
herc8000's Avatar
Just Brakes are Crooks. They use the $99 to get you in the door. Then they tell you need to have your calipers rebuilt which is bs, they use cheap brake pads. They dont put all the parts back on. Dont let anyone you like use Just Brakes.
Old 05-31-07, 03:09 AM
98 GS
98 GS's Avatar
i went there to get the rear brakes done on my lexus and got riped off paid close to 300$ just for the rear,wow did i get screwed,but hey you live and you learn.so dont go there
Old 05-31-07, 07:25 AM
speedaddic
speedaddic's Avatar
haha...classic "Friends don't let Friends use Just Brakes"
Quick Reply: Has anyone used Just Brakes??
