DIY: IS350 front brakes (w/o removing caliper)
Old 11-16-13, 09:48 AM
  #211
Madog350
Madog350's Avatar
Default Rear brake DIY
I'm looking for the rear brake DIY can't seem to find one for is350
Old 11-16-13, 08:00 PM
  #212
isdsms
isdsms's Avatar
https://www.clublexus.com/forums/sus...s-of-pics.html
I didn't need to remove the calipers, just the hardware. It is a very easy job.
Old 11-19-13, 04:06 PM
  #213
Sportskid1
Sportskid1's Avatar
Agreed that the rear are super easy as well and you can leave the rotors on. Just did my second break job and it took me an hour front and rear for the pad swap.
Old 01-07-14, 01:50 PM
  #214
IonSpray35
IonSpray35's Avatar
I went through several pages but it doesn't seem like you used the Fit Kit. Did you re-use fit kit parts as well?
I am about to do my brakes for the first time at just over 116,000 miles. I never did the TSIB for the low dust pads.
There's a chance they changed the brakes before I bought the car, at ~23,000 miles but even still, 90,000 miles is pretty nice.
Old 01-07-14, 01:51 PM
  #215
4TehNguyen
4TehNguyen's Avatar
you can reuse them, just get some brake cleaner to clean them up and new anti squeal grease
Old 03-05-14, 02:45 PM
  #216
RocketGuy3
RocketGuy3's Avatar
So the brake shim kit never needs to be replaced?
Old 03-05-14, 06:20 PM
  #217
Gville350
Gville350's Avatar
^As long as the shims as structurally fine, I don't see a reason to replace them.
Old 03-05-14, 10:11 PM
  #218
RocketGuy3
RocketGuy3's Avatar
Hmmm... OK, thanks. I ask because I called up the dealer, and they want only $90 in labor to change the pads, which is worth it to me, except they say that they replace the shims while they're at it. I was thinking of asking them if they could re-use the same shims, but I suspect there might be extra labor charges to clean and re-use them which would cancel out the cost of shims.
I replaced the front pads myself a couple years ago and re-used the shims, but they were getting dirty and beaten, so I don't know if it would be such a bad idea to replace them at this point (~7.5 years and 83K miles).
... When I did the job, I also lost that little hair-pin like thing that holds the brake pad spring in place and replaced it with a paper clip, haha. I hope they don't want to replace my whole brake fit kit as a result...
/lifestory
Old 03-09-14, 10:13 AM
  #219
tboo72
tboo72's Avatar
Thanks for the great DIY. My newly acquired IS350 had really bad squealing fronts. I used your DIY and replaced the stock front pads with Centric Posi-quiet pads in 45min. Easiest brake job I ever did & my squeal is gone.
Old 03-18-14, 07:48 AM
  #220
garrett56
garrett56's Avatar
Thanks for this great write up. I had never changed brake pads before and did the front pads on mine this past weekend and everything went smoothly.
Also had fun bedding them at 2am with no traffic. Just glad no cops were watching.
Old 04-05-14, 03:34 PM
  #221
Andreben
Andreben's Avatar
Default great DIY writeup!!!
thank you for taking the time do this
Old 05-06-14, 09:50 AM
  #222
stanjohn12
stanjohn12's Avatar
Originally Posted by javyLSU
3) I think the IS300s have brakes similar to the US IS250. You'll be able to tell immediately which brake DIY you need. The IS250 DIY is here if you need it.
Javy
Just for others who own the 2IS 300 ( Gulf Spec ) , the brakes are similar to the 2IS 350 US models not the 2IS 250.
Old 08-25-14, 04:24 PM
  #223
mandyfig
mandyfig's Avatar
What's the torque on the caliper bolts? 68 ft-lbs? Thanks.
Old 08-25-14, 04:27 PM
  #224
mandyfig
mandyfig's Avatar
I read it is 58 ft-lbs. Whoever owned this IS350 before me skimped on the anti-squeel shim plate and eliminated it! You cheap bs. Hence the brakes were squeeling. Gotta get some.
Old 09-20-14, 01:31 PM
  #225
pewtang
pewtang's Avatar
this method work with gs350 08 ?
Quick Reply: DIY: IS350 front brakes (w/o removing caliper)
