Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300 > Suspension and Brakes
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 03-29-07, 11:03 PM   #1
MJHSC400
Trader Score: (0)
Default Swaybar Bushings-- $12.99 -- Energy Suspension-- Installed and awesome--
What's up--
I have been going through the entire suspension save struts-- as they're fine-- and my upper ca bushings are fine too--
I have replaced --
LCA Bushings -- Daizen installed
End links -- Supra TT's from rockauto.com
Swaybar Bushings-- $12.99 for Energy Suspension 1 1/8" poly from autozone
Steering Rack Bushings-- daizens
(did the motor mounts too which is a nice [mod])
About The bushings--
All these upgrades have made a HUGE difference in the way this car drives and handles-- it's now quiet, no clunks, pops, cla-dunks's, or duddadudda's -
When I found out that I could just install the energy suspension universals WITH the supplied brackets with integrated grease points-- A nice upgrade in itself-- What's more? $12.99 -- nuff said -- perfect fit--
All you have to do-- the brackets need to be ground (a little) to the length of the oem brackets, and round the edges-- The oem brackets WONT fit the energy bushings-- sorry.. Who cares, the new one has a grease port-- way better.
The install is easy-- and you get grease points with it-- I couldn't believe how cheap this is to do-- you just need a grinder or a friend with a grinder. Either will work, even if your friend doesn't...
Results of the front suspension rebuild --
The SC I'm driving is old for sure, but has lots of life left for running the roads a good few more years until I can get that blue 996 -- (more on that later)
The tightness and handling have been not only restored but improved on-- Between the daizen rack and lca bushings, and the super stiff swaybar bushings combined with new supra links, the car stays FAR more flat and controlled in a hard (hard!) turn--
Tramlining!!!
I got none-- It's gone after replacing both the end links and the sway bushings-- Imagine that-- soft swaybar bushings causing tramlining--
The Ugly
The factory bushings are SOFT!! All of em--
I'll be doing all the rears next year, but will try to use a universal for the rear swaybar bushings too in the next week or so--
The soft factory bushings suck anyway, and we bought these cars as they LOOKED like sports cars-- Well-- you can get them that way with a little bit (alot) of work--
--Summarized--
DAMM My car feels a hell of a lot better than the day I drove it home-- Now I want to keep it--
__________________
99 ES300 220k and going strong
92 SC4 sold with 180k and ran perfect
I have a dodge truck but nobody probably cares
MJHSC400 is offline   Reply With Quote
Tags
930, apply, bar, bushings, change, diameter, energy, grease, lexus, link, poly, rear, rx300, stiffer, suspension, sway
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
