Cross Drilled Rotors for IS
#46
Tech Info Resource
Stop reading the magazines. They are hurting your ability to make good decisions without the marketing hype. Look at the examples posted above. Minimising sidewall flex is SOOOO over-rated...
#47
This is the most interesting performance thread that i've read so far. My oem rotors warped at 10000 Kilometres because of god knows what and the brakes starts making cracking noises wenever i make turns. Its replaced for free but now its starting to make that cracking noise again with only 1000 Kilometres on the rotors.
Anyways, now im starting to appreciate my 16's lol
#48
I realize that you were talking about cross drilled rotors, but I still disagree about them always reducing surface area. The cross drilled rotors I had on my car years ago actually increased surface area to the air. However, the cross drilled rotors on my motorcycle did reduce the area. It just depends on the thickness of the rotors, and the shape / size of the holes.
#50
#51
If the holes are very, very small, in very thick rotors then yes, you can increase the surface area but they would have to be tiny. However, the aftermarket bbk/rotor manufacturers want to show off the holes and I don't know of any that make them with function over form besides possibly DBA.
#52
You're still going to have reduced heat capacity with less rotor mass to deal with. Even if we take your hypothetical rotors with the chamferred holes as an example, the rotor will invariably reach a higher absolute temperature compared to the same rotor that is not drilled.
Whether it provides better cooling or not in between braking stints, the goal is to keep the absolute temperature as low as possible to prevent pad fade and to keep the fluid from boiling. No?
#53
I guess if you want to get into the theoretical since there isn't a manufacturer (that I know of) that does this....
However, the chamferred holes weren't theoretical. The drilled rotors I had on my '91 Integra were Brembo OEM blanks with chamferred holes.
#54
Tech Info Resource
The benefits of improving airflow to the brakes far exceeds any other modification for track use. None of these mods provide a measurable mechanical performance improvement for street use.
It is not difficult to improve brake airflow on the 2IS platforms. We already have ducts from the bumper into the wheel well, so fitting some kind of ducting would be pretty straight forward. I just wouldn't consider it for a street vehicle.
#55
I was one of them brainwashed by aftermarket brakes marketing. Hey, if it looks more aggressive it must give better performance right? Wrong. Thanks to this thread and the Pulp Friction article I have been schooled. I like the way they start by saying "Your brakes do not stop your car." Sure got me interested to keep on reading. I'm not going to spoil it by posting what actually stops our cars. You have to read the article if you didn't already. It was written by an anti-lock braking engineer who races in the SCCA ITA class for fun.
Thanks for the link lobuxracer!
Pulp Friction Article
