Drill and sloted rotors on the rear clicking (HELP)
I put a set of drill and sloted rotors on my GS the back is clicking real loud its driving my crazy,,,I change to just drill and it still clicks could it be my pads any info well help before I buy pads and that s not the problem Thanks
i have the same problem, i got brembo rotors...and some pads it clicks every time i brake , sounds like coming from the rear, happens more often when braking at slow speeds , i am sure getting new pads will not help? or maybe it will? i asked the tech guy at lexus he said cuz the rotors are new so it will happen and it should go away that was like 5 months back the clicking sound is still there...
Thanks will look into it. Is it only Lexus or the type of rotors I have friends they have drilled and sloted rotors and they dont click
The sound is normal........Even with the shims you will get some buzzing type sound while braking. That is the sound of the pads touching the surface. Remember, theses rotors are slottled & crossdrilled, NOT SMOOTH..Try rubbing your nails across a grater and a face mirror for example... Which do you figure will yield more sound?
The sound it makes is like when you were a kid and you had a pop sickle stick tape to your bike so you here the clicking sound as you rode down the street thats what my car sounds like my kids tell me they here me coming down the street is that the sound you say it going to make.
