Finger Gaps & Rubbing Issues!
Guys,
I would like to know about the majority of you guys on the gaps at your rear tires and its fenders. What is the average space clearance from the tyre to the fender?
I am using coilovers with Dunlop SP9000 275/35/18 tires on my rears with 1.5 finger gap between the tires and the fenders, while my front has 1 finger gap. From time to time when I’m going at about 80 – 100Kms, the tires seem to rub against the rear fenders. (which is really annoying)
I am not sure whether:
1) My height settings at my rear are too low?
2) Or the tyre model (Dunlop SP9000) that I am using are too “rounded” wide (when being compared to other brands)
3) Or whether I need to set negative cambers to the rear?
Could anyone could post pics of their finger gaps at the rear end of their car, just to get an idea whether my settings are too low? Or I should go change for a more appropriate tyre model?
Here are the pics of my rear tires and the fender (right side)
Appreciate the advice & opinions
You have 18's and your rubbing at high speeds? Very odd. I'm no wheel expert, but, my shot in the dark would be to say maybe its 'your wheel offsets'? In your pix, your car doesn't look low enough to rub on highways-unless you have really bad roads up there...anyway, i'm no expert, just my $0.02!
Anyone has pic of their shaved fenders? I would set the cambers to negative. But a pic may give me an idea. This rubbing never happened when i was using my old tires Bridgestone Potenza GIII.
Take off those black fender arch strips. Four phillips-head screws, problem solved.
Master Thread Closer!!
I think a combo of things....
- Wheel offset too low (sticks out too much).
- Tires too "square". Im on Dunlop Direzzas....275/30/19 in rear....and the edges on these tires are designed to taper inwards...that helps a bit to avoid rubbing.
- Coilovers are too soft....too much travel......can dampening be set stiffer?
- Camber....a bit negative camber is always good.
Goodluck.
Pete
Goodluck.
Pete
Here's my old thread on the Direzza.
https://www.clublexus.com/forums/sho...hlight=direzza
Here's a pic...
pete
Here's a pic...
pete
I had Direzzas on my previous wheels. On 9.5'' wide wheel they looked stretch'd a bit, but on 10'' wheel those tyres will give you a decent amount of space you need. I personally liked them for its price
Here's a pic...
pete
Here's a pic...
pete
NOW that is a tyre type/model I am looking for! It is more likely to solve my rubbing problem.
Gonna fully utilise the existing "square" tyre to the max and then I'm gonna look out for direzza or something similar.
