TRD Lower Suspension Brace and Strut Brace
Is this TRD lower suspension brace and/or TRD strut brace worth getting? For those who have installed it, can you please give me your review? Can you notice any improvements in handling. Thank you for your replies.
I originally had only L-Tuned shocks, springs and steering ECU on my 2001 GS430 with Lowenhart BR-5 18x8.5 245/40R18 SO3 (F) and 18x9.5 275/35R18 SO3 (R) rims/tires. There is a particular steep uphill climb with a small bump at the middle that when I drive at about 65+ mph as I hit this bump on one side my GS would have a unsettling feeling on the landing and by GS would roll left to right a bit. It feels as if GS would like to go a little side way. When I pick up the TRD STB and Lower Chassis Brace from Steve Ganz I notice that the problem no longer exist. My hood seems a bit flatter on a irregular bump on one of the front wheels only (now the L-Tuned spring and shock are doing the job of absorbing the irregularities instead of the flexing of the car body). Also, on tight circle turns the front is also flatter. The car still leans but less. If I had gotten the TRD anti-sway bars I think it would be even better improvement but I did not want to sacrifice my current ride comfort. I am now thinking about getting a rear STB and a front STB that would fit a GS430 engine cover (currently running without the cover).
Chu...
Chu...
STB will be more noticeable (tightening of ride, not harsher, just less flex) than LCB, since there's already a LCB on the car. I just got it because I figured might as well do the whole enchilada.
Hi MooreTorque:
One of the ClubLexus member "V300" said a C-one STB fits a GS430 with the engine cover on. The problem was the C-one STB is a bit pricey (about $400 - too much for a part that rarely is seen and the current TRD is doing just fine). I only paid $180 for the TRD STB. I was going to wait and see if other vendors or even TRD will be releasing one that would fit a GS430 with the engine cover. I am sure there will be it just take a bit longer as it has been only 1 year since the release of the GS430.
Chu...
Chu...
I currently have the Ltuned spring/shock with TRD F+R sways, running on stock 16's, soon to be 18's. I am already very happy with the ride quality, no more floaty feeling, and i can feel more control of the car when going above 90 (rarely ofcourse ). When I first had the install, the ride quality was stiffen up quite a bit, I can feel the road much more, but compare to losing control of the car at high speed, there is no comparison.
I am wondering, do you guys recommend gettting F+R STB also? how much more help would that do for the handling? How about ride quality?
Hey, Lex 430
Lex430,
Did you do the L-tuned and the sways at the same time or separately?
Reason I'm asking is I have the L-tuned and steering ECU and I'm considering the TRD sways. I'm just trying to gauge the handling improvement vs. less ride comfort tradeoff if I add the sways.
Thanks for any comments.
Re: Hey, Lex 430
Originally posted by duster
Lex430,
Lex430,
I did the altogether, I thought about doing it separately so I can tell how much difference between each item, but cost/time saving wise, it was alot easier to do it together. So, the improvement from stock was dramatic for me. I like it alot. But I wonder how much more improvement I would get if I get STB now,
Guest
Posts: n/a
TRD will not have the STB for GS430 because in Japan, they only have S300/V300. Same thing with TOM'S ECU, they will not have one for GS400/430 simply because they don't have that in Japan. Perhaps L-tuned might develop a true ECU (not steering one) or STB, afterall, TRD is for Japan, L-Tuned is for U.S., TTE is for Europe and etc. This has been confirmed by our TRD guru, Steve Ganz.
Re: Hey, Lex 430
Duster - don't know where you are, but maybe you can find someone with sways to take you for a ride.
ChuH, read about C-one. Like you, I have been waiting for other vendors (incl TRD) and thought, with your post, that there might be another. The C is pricey, but considering that I'll likely be keeping this car for as long as my last SC (almost 8 yrs), it amortizes ok. Still, rather have it cheaper if I could. Thanks for your rapid response.
lex430, STBs won't affect ride quality noticeably. Turn in should be a bit sharper, since less of the force applied to change direction will be lost to chassis flex. Cornering over bumps, esp. those that just affect one side, should be more stable also. And (at least with time), maybe less squeaks/rattles since the "chassis" is actually more or less a unibody with components attached to it. The big components (suspension, motor, etc) won't really loosen, but all that interior stuff will. And you'll be stunned how much difference the 18s will make over the 16s (considering the difference between the 16s and 17s is already considerable)!!!!!!!
Lex430 & Bit,
Thanks for the responses.
I live in the Los Angeles area...Pasadena to be more exact.
I'm not sure what else I want to do on the suspension.
Get this...my wife loves the Ltuned shocks and springs because she says when she is a passenger and I take a corner a little quicky, she no longer gets bounced around in the seat due to the body roll. So this along with how much I like the firmer ride gave me the green light to consider more suspension goodies.
I'll have to re-read old suspension related posts now that I am more interested in this type of upgrade. Bit..I hope you get the VSC issue cleared up !!
Lex430 Bit..I hope you get the VSC issue cleared up !!
