What is a fair price for kyb gr2 install?
Just like the title reads, how much should I expect to pay for the installation of my kyb's? I have gotten quotes from $350 to $300 and I only paid $250 for the shocks and struts.
Also, I posted a reply asking the same question just a minute ago to another thread, but how much should it cost to have my new ball joints installed? Obviously I should do them both at the same time right? Wont this save me some money on labor? How much?
Lastly, where can I find the daizen bushings that I have been reading about. Maybe I can have those installed too. How much do they cost to install? I am looking for dramatic improvement in my ride quality after this and I am open to suggestions. Thanks.
$300 seems about right for shocks. I would the balljoints should be included in that price, they are really easy to do. Bushings, if you buy the daizen ones, look to spend some money there. I did them myself, and it is not easy. A lot more stuff has to come off, the castor bushings are a huge PITA to take out. I would say a couple of hundred for the bushings. But if you do it all at once, you should be able to catch a break. I would say $500 and under to be fair for all of this. I think carson has the bushings. Just look in the vendors section. They are about $100 for the entire set.
I paid $300 a couple of years ago to have my L-Tuned shocks and springs installed. I also had an alignment done for $79. This was from a Lexus shop not a dealer.
Im going with a local shop I found that deals with a lot of imports. They quoted me $300 and maybe that will include the ball joints once they see how easy it should be once they are in there. I really need to find one good shop and stick with it so Im keeping my fingers crossed that these guys are a one stop shop.
I got quotes around $400-$500 for mine so i decided to do it myself. It took aprox 8 hours to do all four. Rented a spring compressor from AutoZone and bought a 120 volt impact wrench from Walmart (definitely needed to compress the springs). Not a hard job at all with right tools, this is the second time i've done it, so i wanted to save money and do it myself again. Saved time by not removing the upper control arm, just turn the wheel and they slide out. Good luck man...
I had been quoted 400 by both Lexus and general service shops to replace all 4 shocks and struts. I was to supply the shocks and struts.
I ended up doing it myself. As stated above, you just need a good spring compressor (rentable) and the right sized sockets. I had an air compressor and gun so that helped of course.
$300 is in line with a spring/shock install. Ball joints will probably be extra at almost any shop you go to. If you want to do the full Daizen bushing kit do yourself a favor and have a shop do it, it's also going to be expensive labor wise. It will be less than buying new arms but still a hefty chunk of change.
Thanks yall! Im just doing the ball joints and struts for now. I asked the same guys about the daizen bushings and they quoted me a grip! I sent them some info about tightening the pretensioner and they seemed willing to try so I think I will do that too while Im there. Im hoping this makeover will dramatically change the way may car feels! Ill let yall know how it turns out friday.
linusls400
14
12-06-05 09:36 PM
bezeeduzit
Suspension and Brakes
07-28-04 06:15 PM
