DIY Daizen Steering Rack Bushing
LSUGS430 (11-17-22)
#47
Actually the hard bushing on the control arms do degrade the ride quality as far as soft ride. The rubber bushings are there to dampen and absorb bumps transmitted to the body. I know a few people who have them and they transmitt bumps to the body of the car. " Degrade " is a relitive term !
LSUGS430 (11-17-22)
#48
exclusive matchup
so let's see when i will have the chance to bring the car in
LSUGS430 (11-17-22)
#49
I'm debating if I should do this or not. My car only has 18k miles right now. Does this new bushing get rid of ALL the slop in the steering? I have about 1/2-3/4" of play either way on the steering wheel. When I try to turn the wheel while the car is parked with the wheel at dead center...the first half inch or so does not do anything. It's only after that first half inch that the wheel on the ground will start turning. I know this is probably nothing compared to some of you guys with 100K+ miles on the clock, but it still annoys me for a "sport" sedan to have steering like this.
#50
#51
GSteg, you are the man. I just did these on sunday. Your instructions were perfect. The only thing I did different is that the top bushing, I took it out the same as the bottom. With the same scredriver, except hitting it from the front, toward the back. Took me exactly an hour to do, only because I thougt that I was slick and would just do this on ramps, then midway through removing things, I realized that jack-stands would be better. So I had to re-elevate my car. Which wasted some time. The stock bushing were as soft as the weather stripping in our doors.
The feel is superb. This is the first suspension upgrade I have done so far, so my differences from before might feel extreme. But steering is 100% more linear. It now requires a lot less steering corection while driving, and the response to steering input is instant. And one more strange thing happened, my road noise decreased, a lot. I mean before, my tires would **** me off, i would raise the volume to drone them out. Now they are barely noticable, I only have windnoise on the highway now. Thanks again. Great find.
LSUGS430 (11-17-22)
LSUGS430 (11-17-22)
#56
Agreed, read my previous post. Ramps suck *****. You will not be able to work under there. I tried and it is not worth the effort to even try with them. Maybe if you are like 100Lbs, and don't use a creeper, you might be able to do it. But why waste time to even try this? Use jackstands lift that sucker about 2 feet up (frame, not the wheels), and go to work. It is very simple under there when it is higher up, plus you can use a creeper.
#58
1. Less Slack in the wheel
2. Much easier to keep the car straight
3. A **** load less tire noise than before. I guess the rack doesn't move around anymore.
4. Instant steering responce.
5. Steering wheel stays straight. We have crowned roads everywhere, and my steering was always a littl to the left. Now it is pretty much straight.
6. Superior steering feel than before. Every time I start driving I notice it being better.
You can't go wrong for $50 and an hour of your time to install it.
LSUGS430 (11-17-22)
#60
I agree. Before doing this mod, my car would steer to the right if I had left my steering wheel straight. I thoguht I had an alignment problem, but then I did an alignment only three months prior and have only put on 500 miles since. These bushing corrected my steering and now my car goes straight.
LSUGS430 (11-17-22)
