trd sways and daizen bushes?
looks like i'm ordering my trd sways from japan direct..anyway, i have the daizen polyurethane bushes fitted with stock sways..will the trd sways fit with the bushes or do i need to get trd bushes?
thanks
thanks
They are completely different bushings. The TRD ones are rubber pieces not polyurethane and it is also a bigger inner diameter than stock. The upside to all this is that the sways will come with a set in the box if you buy them new. Downside is that they are not so readily available or easy to find when they eventually wear down. You will have to hunt for a set thru TRD Japan.
///MDex
Suspension and Brakes
37
07-01-03 10:51 AM
