Vibrating Brake - PLEASE HELP.
I just replaced new brake pads and rotors for all 4 corners and when I drive, I experienced some vibration when I applied the brakes. I have read a few threads and all pointing to the rotors but they're brand new!!!
I also read some that said to grease to pin. What pin is it? can some one help?
Info:
1. The rotors are off Ebay and they're crossed drilled Brembo OEM.
2. Pads are EBC green.
3. Did not bleed the brake lines.
I notice on the EBC pads there is a breakin coating. Does this have the vibration effect?
Any advise?
Info:
Any advise?
dubsonlexus
Info:
Any advise?
Info:
Any advise?
How can I tell if the direction is correct? I read many posts on here but both directions were use. I did followed the recommnded direction. what is the rule of thumb on direction. Thanks
