Lowering Using New Tein CS
Old 08-08-06, 05:03 AM
carmcanc
carmcanc's Avatar
Default Lowering Using New Tein CS
I ordered the Tein CS coil overs to go on my 98 GS4 with 18's because I wanted to lower it a little and close the gap but I was wondering how it will affect the alignment. Do the Teins come from the factory set to lower the car by a certain amount? If I lower the car will I be able to get a true alignment? I have read threads that say you can't get the car within the original spec once it's lowered, is that true or is that true only if you lower a lot. Any advice would be appreciated.
Thanks in advance,
Carmen
Old 08-08-06, 09:26 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
can't say much about the lowering, i never follow it anyway. but i am pretty sure you have wide enough of a range on lowering to do what you need here (doesn't sound like you want to slam the car)
the fact is on the gs, mild lowering will start to throw out the alignment already. i think even with ltuned drop, maybe 1" or so? the alignment will be right at the boundary
Old 08-08-06, 10:26 AM
AJ
AJ's Avatar
I installed mine just the way they came (ive got 18's too) and got a 1" drop in the front and .25" drop in the back which is perfect for me (3 finger gap each wheel) and no alignment yet !
Old 08-09-06, 06:22 AM
SloGS3
SloGS3's Avatar
You probably wont be able to set your camber back to factory specs but you can set the toe. Its ok to run some negative camber as long as your toe is within spec youll be fine. Try to get both as close as possible to stock, just make sure that toe is dead on, and if you have negative camber it wont hurt, it will just help you in the twisties!
Slowk20a2
Suspension and Brakes
04-10-13 12:26 AM
KKRlexus
05-26-07 01:35 AM
TYPEII
04-25-05 02:35 AM
pvo
Northeast
05-03-04 10:30 AM
dnguyen_GS430
11-16-01 08:34 PM
Quick Reply: Lowering Using New Tein CS
