Daizen Bushings Install Step By Step *56K Warning*
Old 10-18-08, 06:50 PM
scoarer400
scoarer400's Avatar
Originally Posted by scoarer400
just bought a kit for the fronts.. i plan on installing them over the weekend, myself.. wish me luck!
oh yea.. so do the old bushings have to be pressed out? or can we torch em out? same for the new bushings.. do they have to be machine pressed in?
Old 10-27-08, 07:27 PM
cazman
cazman's Avatar
These guys do the lower sock bushings, wel they do the entire car actually, you may have to look under A80 supra
http://203.31.191.243/fulcrumCat/
Old 10-28-08, 05:51 PM
basc300
basc300's Avatar
how much does the kit cost and does it come with both sides
Old 11-04-08, 12:37 PM
msc300
msc300's Avatar
how long does it take each side for upper and lower bushings
Old 11-06-08, 11:54 PM
Holshot
Holshot's Avatar
Never heard of these guys... anyone have any experience? If so do tell! Thanks for the link BTW...
Joe
Old 07-10-11, 06:14 PM
CCC-TT
CCC-TT's Avatar
Reviving the thread.
The 97+ LCA's appear to have different sleeves, any input on how I should tackle these?
Old 07-11-11, 07:33 AM
CCC-TT
CCC-TT's Avatar
Problem solved thanks to input from RedPheonix, I'll post some pictures in the next day or two regarding the slight differences involved in installing bushings into 97+ LCA's.
Old 07-13-11, 08:13 PM
booja
booja's Avatar
i need to do this bad on mine
Old 07-14-11, 06:23 PM
CCC-TT
CCC-TT's Avatar
I just finishedup about 20 minutes ago. Besides the eccentric bolts being sezed inside the inner bushing sleeves this was relatively simple. I never needed a press; a $20 plumbing torch from home depot did the job. Just got back from the test drive and i can really feel a difference. Definitely worth doing.
Old 08-09-11, 02:16 PM
cmh
cmh's Avatar
so i had a mechanic press out the lower controll arm bushings out and he bent the little metal shell (cup) that the bushing goes into... i hope im explaining myself right...
so u have a lca when u press the bushing out it has a shell around the bushing(metal) and inside the bushing has a long metal washer the screw goes thru...
the shell (highlighted in red above) is what is is bent!!!
do i need to use that shell or can i put the bushing straight into the controll arm???(no shell)
please help
Old 08-09-11, 02:53 PM
cmh
cmh's Avatar
3rd post, 4th picture... that gold cup, the stock one bent... i bought a prothane kit and it doesnt come with that cup...
please help
Old 07-14-12, 05:14 PM
SEIDO
SEIDO's Avatar
Can the '92-'96 Bushings somehow be fitted to the '97?
Old 07-19-12, 09:37 AM
D1GP
D1GP's Avatar
Give Daizen a call.. I am not too sure
Old 07-19-12, 08:48 PM
mcannaday
mcannaday's Avatar
Just asking opinions, I am installing new sway bar bushings, steering rack bushings, and 4 new struts.
Should I install both Front and Rear control arm bushings? or just the fronts? Cheapest place to purchase all of them together? JEGS has them cheaper than Daizen, quality loss?
rwdanthony
Suspension and Brakes
39
08-03-10 01:13 PM
kingrich
05-25-08 01:11 PM
aasc300
61
01-24-04 04:40 PM
DIrEctQL
SC- 1st Gen (1992-2000)
18
12-04-02 03:00 AM
Quick Reply: Daizen Bushings Install Step By Step *56K Warning*
