New TEIN CS Replacement
Here's one of several key differences with the new CS called MSV.
Use of new feature M.S.V. (Micro Speed Valve) realizes both high controllability and ride comfort surpassing that of TYPE CS. As a result, everything; sporty feel transmitted through steering wheel, comfort in every passenger seat, etc., adds up to over-all pleasure, just like European cars.
Anyone with the old version of the CS that just ordered from Todd. Can someone weigh one of their coilovers before getting them installed?
This will be one way to quickly settle the issue of whether the new CS will weigh more than the original, since the shell case has changed from aluminum to steel.
The new shell case is made of steel and its surface is treated with specially formulated Fluorine for protection against rust and corrosion.
Originally Posted by RMMGS4
Available May 26.
Let's see if Todd will do a GB on these !
Originally Posted by LXOGOOD
Looking good....
Glen, any info regarding the EDFC? I wonder if it will be a direct fit with the new setup?
Ken,
well I know the 16 adjustable settings are still available, so you would hope they made the EDFC future compatible with this new design.
According to the Yen pricing I saw, the retail value calculates to $1260.
This is a no brainer purchase for me. Next group buy , I'm in.
Ken,
I'm with ya. Time for some new coilovers.
Originally Posted by ktang235
Can anybody translate this
http://www.tein.co.jp/cst.html
Sure, but keep in mind how the Japanese language does not translate well to English. ESPECIALLY when it comes down to knowing the difference betweeen ? and ? and ? , and then there's ?. :
On Sale beginning May 2006
Maximizing road holding and comfort, 'COMFORT SPORT' provides solid feeling just like sophisticated European sport vehicles, without sacrificing ride comfort. With its sublime style, 'COMFORT SPORT' surely is for mature adult who enjoys both controlling and dressing up the vehicle.
Concept
Setting
Improved Rust Prevention & Luxurious Design
Shell case is coated with the special fluorocarbon resin for superior corrosion resistance. Gold Alumite seat lock and upper mount on black shell case would provide not only high performance but also satisfactory appearance.
Accommodating Larger Tires/Wheels
We have used bigger size wheels and tires, which are expected to be most popular ones for the particular vehicles, when developing and testing COMFORT SPORT.
A. Upper Mount
Exclusively designed reinforced rubber mount is used to maintain the calmness and comfort, yet enabling direct driving feel and handling surpassing performance of OE mount. (Some models are used with OE mounts.)
B. Mono-Tube Structure
As oil and gas chambers are completely separated, aeration hardly occurs and heat is released quite well, achieving stable performance.
C. Threading Type Ride Height Adjustment System
Threading type system enables adjustment by a millimeter. We recommend adjustment of lower seat to be within10mm (either above or below) from the standard position for optimum outcome. (Vary by lever ratio)
D. 16-Level Damping Force Adjustment Feature (Comp./Rebound Together)
COMFORT SPORT is equipped with popular 16-level damping force adjustment feature (compression / rebound together). Use of specially designed needle valve allows linear damping force generation at all 16 levels. Drivers can enjoy wide range of setting capability.
E. Brand-New Feature: M.S.V. (Micro Speed Valve)
With newly developed M.S.V. system, required damping force in very low speed range can be well maintained for improved steering response, and in turn improving traction performance to maintain firm handling.
Click here for more information on M.S.V. (Micro Speed Valve)
F. Shell Case
Shell case is made of steel and its surface is treated with specially formulated Fluorine for protection against rust and corrosion.
G. Spring
Straight spring, made of no-sagging, high-tensile steel with tensile strength of 200kgf/mm2 (1960N/mm2). Exclusive spring is used for vehicles with separate spring / shock absorber set up.
H. Complete Kit
Shock absorbers, springs and pillow ball upper mounts come in 'complete kit' to assure correct settings.
