Camber wear!!
Camber wear!!
How bad is yours? I just bought new tires and already camber wear on front two tires. I'll have pics up soon but wondering how bad everyone is. I know there are previous threads about this but wanted to get NEW pics. I have it dropped on tein springs only. Let me see how yours are. Thanks
-Kenji
-Kenji
wow... same thing with me, I bought some rims last summer the original owner put around 2000 miles on the tires, so I put them on my car with a set of teins, and 3000 miles later my front wheels needed new tires. They were down to the metal on the inside of the tires, anyways I took it to belle tire for some new tires and another wheel alignment, the guy who worked on it told me that the problem was from the coilovers. Well I hope these tires last cuz I dont think its worth it to spend 450.00 for new tires every 5000 miles.
Ask around for the best alignment shop you can find. I had my alignment done after the L-tuned install at some local ****-****ing-hole and after 2k miles on my brand new 17" tires, all sides were eaten up. Went back and they did it again. Those tires lasted 9k. Finally went to an awesome shop near me, and they said front and rear camber and toe were totally ****ed. Tires are now wearing evenly (slight camber wear on inside rear, but rotation keeps things looking even).
This is also a concern of mine, I just lowered my car on Tein CS and had it aligned...The camber is barely "out of spec" on all for corners and the Toe is within specs....unfortunately I cannot rotate my tires since they are staggered but I plan on gauging the wear on these as I go...Luckily this is not my daily driver or things would be different
exclusive matchup
i forgot exactly how it works, but have to check again on toe. i was told that even within spec, the toe could put excessive wear on the inside. you probably need a bit more toe in for the front wheels, coz' when you drive, the wheels will start to toe out. if the toe isn't enough in the first place, you start to have inside wear
someone correct me though
I am very low and have had camber wear on all tires but the the new Toyo T1R seem to handle the wear pretty well. No problems yet and they are at about 10k miles. Hopefully I can get at least 20k to 25k out of these tires
exclusive matchup
Originally Posted by sockfocks
Somewhat correct on the fact that excessive toe out causes inside tire wear, excessive toe in causes outside tire wear. On a regular ride height I have had inner tire wear due to alignment issues on other cars, so its not limited to strictly being lowered. I told them to keep the toe-in as equal as they can and not worry about camber as long as it wasnt too far out. Seems either one has to go out of spec when you lower the car.
I see on the Sewell Lexus site that the have Daizen front and rear camber adjustment kits. At some point I remember reading that no such kits were available for our cars, so are these fairly new products (and if so, does anyone have them?? are they worth the investment??)
Somebody correct me if I'm wrong but doesn't the 2001 - 2005 GS have front and rear camber adjustments?? While installing my Teins I saw adjustment bolts both on the front and rear..
What about you guys who have a 98' - 00' Gs do you have camber adjustments front and rear??
exclusive matchup
exclusive matchup
