HELP: Installing L-tuned Ecu / Steering wheel pretensioner
This topic has been discussed over and over again, but can someone provide some pictures to help me install my l-tuned steering ecu? I know you have to remove 2 screws and 2 clips inorder to remove the panel underneath the steering wheel, but im not confident in what im doing. I also know that you can just slide the ECU off the bracket as oppose to removing the 10mm bolt. Im not totally lost, but pics would definitely help!
Lastly, i want to tighten the steering wheel pretensioner, but im not sure where to look for that hex nut? If someone could provide a picture as to where it exactly is, i can do this tomorrow.
So i attempted removing the stock steering ecu by sliding it off the bracket and realized it was harder than i thought i would be. I was concerned about breaking something, possibly the bracket or the casing of the stock ecu since it just wouldn't come off. I was successful in removing the bracket off the Ltuned Steering Ecu, but just no luck with the stock unit. I think i might just bring it to my shop to get this done.
bad-gs400
Suspension and Brakes
47
06-27-02 01:55 PM
