Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300 > Suspension and Brakes
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read GarageUsed CarsVendors TSBs & Recalls
Welcome to Club Lexus!
Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
Thread Tools Search this Thread Display Modes
Old 02-09-06, 11:44 AM   #1
TexasSC400
Garage is empty, add now
Trader Score: (0)
Default Are new Strut Mounts needed?
Hey Guys,
I'm having new Tokico Blues and Tanabe Coil Springs put on it my 1992 SC400. I think this is the first time its ever been done. One of the shops I'm getting quotes from to do the work is quoting new Strut Mounts. Do I really need new ones? I've heard I can reuse the original ones...or are mine possibly too old. How can I tell?
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
TexasSC400 is offline   Reply With Quote
Old 02-10-06, 09:05 AM   #2
TexasSC400
Trader Score: (0)
Default needing some help
Need a little help guys. I know someone has the answer...or resourceful comment.
Old 02-10-06, 11:14 AM   #3
bmatsu
Trader Score: (0)
Since your car is a 92, you might as well change the mounts, it can't hurt.
good luck
bmatsu is offline   Reply With Quote
Old 02-11-06, 12:49 PM   #4
hitsolid
Trader Score: (0)
I had the same setup installed yesterday on my 93 SC300 (143k freeway miles). I got a look at the old strut mounts and I would recommend installing new ones. Not only for the potential of a better ride but also because the old ones have most likely cracked or broken and will not provide any protection to the new struts.
hitsolid is offline   Reply With Quote
Old 02-12-06, 07:42 PM   #5
stevechumo
Trader Score: (4)
stevechumo's Avatar
Quote:
Originally Posted by TexasSC400
Hey Guys,
Did you mean the rubber strut mounts or the metal strut mounts? If the rubber mounts got worn and cracked, you can use hard silicon, soft gasket maker, or rubber sealant to fix them like in original shape and let them dry overnight. The job is easy and about $5. If the metal mounts with 3 studs on each mount that bolt to the chassis went bad, it's hardly the case. Mine 95 SC has 148,000 miles on them with no problem. However, I believe the KYB has each metal mount for around $45. Or the problem could be the strut bushings that are broken.
__________________
C:\Documents and Settings\Thuy Chu\Desktop\SCEngine3.jpg
Single Turbo SC400 V8 on 15 psi, 392 rwhp and 429 rwtq, Built engine, AEM EMS, Hi-Performance Built Tranny with Shift Kit, Lextreme Hi-Performance Torque Converter, Tein SS, Supra LCA, LS and Supra Bigger Brakes, SS Brake Lines, LSD, Strut Bar, Custom Body Kit.
stevechumo is offline   Reply With Quote
Tags
2003, es300, is300, lexus, mouns, mount, mounts, necessary, needed, new, putting, reuse, strut, struts
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Service | JOBS
Get all contact info
Content Relevant URLs by vBSEO 3.5.2
