Tein CS reminder.
Old 01-05-06, 06:18 PM
Lexy GS430
Lexy GS430's Avatar
Default Tein CS reminder.
Guys it happen again, not long ago my rear left tein cs suspenion fall out of place. I am talking about the bolt that goes around the the damper switch. Anyways last sunday my front passenger side did it too, so all i had to do was screw the bolts back on easy fix it was. So from my experience so far, all i need to do is retorque all the suspenion bolts about every 5 to 4 months depending how often i drive her. Hope this will help so this does not happen to my CL boys. One last thing, if it does happen to anyone that has the CS it's going to sound like a loud clunking sound when you are even goin over very small pumps so don't be to shocked, just stop the car, and retighten the bolt.
Old 01-05-06, 06:41 PM
joshoowa
joshoowa's Avatar
how many lb/tq do u need to tighten them??
Old 01-05-06, 06:46 PM
GWELEX
GWELEX's Avatar
What about using some Red Locktite or something similar? I wonder if those nylon lock nuts would work?
Old 01-05-06, 07:04 PM
Lexy GS430
Lexy GS430's Avatar
That i need to call tein about, but i just tighten enough to where it's tight if that makes any sense.
Old 01-05-06, 07:06 PM
Lexy GS430
Lexy GS430's Avatar
Not a bad idea, but i am planning to have the edfc put on for damping.
Old 01-05-06, 07:15 PM
GS300Rich
GS300Rich's Avatar
There should be some torque specs in the manual. I am wondering if this is a common problem. I havent had this happen to me yet and I have had my Teins on for 2 years
Old 01-05-06, 08:01 PM
Neo
The One
Neo's Avatar
Same here. No issues yet. For people with issues, was LocTite used? If I remember right, the setup comes with some.
Old 01-05-06, 08:19 PM
chuckb
chuckb's Avatar
torque is like 20 lbs. I've tightened mine a little once already. the trick is to use one wrench to hold the shaft in place and another to tighten nut. you can't use a torque wrench on it. I did use the torque wrench on the strut mount bolts and some of them turned a little too.
Old 01-06-06, 07:26 AM
speedaddic
speedaddic's Avatar
for the dummies, what bolt are we actually looking for (where is it?)
Old 01-06-06, 07:29 AM
pvo
pvo's Avatar
Question
Newbie question: What are the locations of these suspension bolts? Pics would help a lot.
I have some strange noise and wonder if I need to tighten something.
Old 01-06-06, 07:30 AM
Lvangundy
Guest
Posts: n/a
Thanks for the post, I think I need to tighten mine, I heard a noise yesterday that might be this.
THX
Old 01-06-06, 08:19 AM
chuckb
chuckb's Avatar
hold the shaft in place on top with a 10mm while you tighten center bolt with a 17mm
Old 01-06-06, 08:22 AM
pvo
pvo's Avatar
Thanks a lot for the pics.
Old 01-06-06, 09:06 AM
joshoowa
joshoowa's Avatar
ahh very nice.. might i add ur engine looks very clean
Old 01-06-06, 09:10 AM
speedaddic
speedaddic's Avatar
That's where I was thinking it was. Thanks for the pics! Helped out a lot
Quick Reply: Tein CS reminder.
