Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation > Suspension and Brakes
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read GarageUsed CarsVendors TSBs & Recalls
Welcome to Club Lexus!
Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
Thread Tools Search this Thread Display Modes
Old 01-05-06, 02:59 PM   #1
praiford
Garage is empty, add now
Trader Score: (0)
Default Creak in Rear Strut/Suspension
Hi All-
Newbie here with a question. I have done the search and am still confused. I have a '00 GS300 that has developed a creaky groan from the left rear when going over speed bumps at a low speed or even when getting out of the car in the garage (I weigh 190 lbs.) I can even make it creak by pushing down and getting the rear end rocking just so. I took it to my dealer and they said at first they would "lube" the rear bushings for $140, then called back and said I needed a new rear strut. I went ahead and had it done, but the noise came back the next day. I am going in one more time next week to leave it again. Any ideas or thoughts? They definitely put in a new strut.
Thanks.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
praiford is offline   Reply With Quote
Old 01-11-06, 08:59 PM   #2
pianovt
Trader Score: (0)
Hello Praiford,
I have the same symptoms on my 2002 GS300. It sounds like some rubber parts are too tight around metal. One possible candidate is the rubber ring that sits between the top of the coil spring and the support plate. In addition, I also hear something like a "creaky squeak" from the front. Would you please let me know what you find out from the dealer?
Does anyone know what the factory uses as a lubricant on suspension bushings and other rubber parts?
Thanks,
VT
pianovt is offline   Reply With Quote
Old 01-13-06, 08:18 AM   #3
praiford
Trader Score: (0)
Default Update so far
I went for a test ride with the service tech yesterday. He heard more of a rattle than the creak/groan. I couldn't replicate the sound either, although the rattle seemed more pronounced. He was going to retorque everything and lubricate the upper and lower bushings in the rear. I didn't ask what they used (WD-40??). I am sure they have something special.
At first my service rep said all it needed was a bushing lube, but then they changed the left rear strut. I hope to pick it today and will update.
praiford
Old 01-13-06, 09:49 AM   #4
PHML
Master Thread Closer!!
2001 Lexus GS
Trader Score: (31)
PHML's Avatar
Peter H. M. Lee
Send a message via MSN to PHML
I got Ltuned susp....and it didn't creak until recently...i just think they need some lubrication of some sort.
PHML is offline   Reply With Quote
Old 01-13-06, 12:09 PM   #5
pianovt
Trader Score: (0)
Hello Praiford,
I just got my car (2002 GS300), so I have been busy looking at the TSBs which are posted somewhere on this site.
There are a few relevant TSBs. Two of the notices pertain to the rubber pad between the spring and the flange; one TSB for the front, and one for the rear. These refer to "clicking" sounds, I think. I don't have that, my noises are definitely creaking noises, particularly when entering driveways, etc.
Two more TSBs I found have to do with the front stabilizer bar brackets. I just checked mine yesterday, and indeed, they were not tight any more. The stabilizer bar was not flopping around, but there was a squeak/rattle from the front. I think I have taken care of that. This is a fairly easy job. You need a torque wrench, a 12 mm socket, extension, and a u-joint for the extension. I would do this with both front wheels supporting the car, so that the torsion bar isn't holding a load.
Pay attention to the two stabilizer bar TSBs; one deals with re-tightening the original design bolts to 18 foot-punds to eliminate the noise. The other TSB explains how they changed the design some time in 2002 to larger bolts and new brackets so that the bolts can be tightened more. Don't tighten the smaller design bolts to the new spec for the bigger bolts!
Regarding the bushing lube, I never liked putting petroleum products like WD-40 on rubber because there is no telling how the rubber will take the solvent. I also doubt that WD-40 would do the job for long. There must be some kind of a specialty lubricant that works well for this.
I would however say that a squirt of WD-40 here and there, if methodically applied, could reveal the problem spot so that it can be dealt with properly.
Please keep me posted about your progress. Thanks.
VT
Old 01-13-06, 04:35 PM   #6
NoS
Trader Score: (0)
NoS's Avatar
If you have L-Tuned and used the provided bump rubber it will start to make noise because it will move as to the factory on staying in place.
Have you considered maybe a blown shock? That would be unlikely though since the tech would have noticed that.
It could also be the bushing going south.
NoS is offline   Reply With Quote
Old 01-16-06, 06:48 PM   #7
praiford
Trader Score: (0)
Default So far so good
Just got home from the dealership. They said that they retorqued everything in the rear suspension, test drove it and didn't hear anything. They didn't say anything about lubing the bushes, but I will check with my service rep (she had the day off so I just picked it up). So far so good - - I haven't heard anything in the rear and I just spent the last 6 days driving around a new GS300 loaner and didn't notice my "old" girl riding or sounding very different. Will let you know if there are any changes. Thanks for all your help. I may still have to use some of the info again.
praiford
Old 01-18-06, 04:09 PM   #8
pianovt
Trader Score: (0)
Hi Praiford,
I am glad they fixed the problem.
I put some silicone grease on the rear sway bar bushings and the noise has gone down considerably. I think there is more than one thing at work here. If the car stays like this, I will be happy. There is however at least one more point that could use the grease, and I don't know where that is.
The rubber bushings had a lot of mould release on them from the factory. That is the whitish stuff that feels waxy. I think that needs to be cleaned off before the new grease is applied.
Please let us know if you learn anything new, or if the noise comes back. Thanks!
VT
Tags
gs300, lexus, lubricate, rear, squeak, strut, suspension
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Service | JOBS
Get all contact info
Content Relevant URLs by vBSEO 3.5.2
