Installed Daizen Control Arm and STill have Vibration.
Hey guys,
I previously installed the Daizen Control Arm kit fr the 98 gs. I had issues at 55 mph for bad vibration, but after the installation he vibration at that particular mph is gone (which is good). I had it installed and allignment done, seemed fine at first but not around 70-75 thre is a small vibration. Not as bad as before the kit was installed. Wondering if anyone who installed the kit are still having issues with vibration. Thanks
-Kenji
-Kenji
Hey guys,
-Kenji
(SOrry about the double post, didn't know the best place to put this)
-Kenji
Originally Posted by chuckb
are you sure your tires are road force balanced below 20lb and in good shape?
-Kenji
Originally Posted by PHML
I just spoke to someone who mentioned the same thing....still some vibrations after Daizen control arm bushing install and alignment.
Any idea on what could be causing this problem? The only thing i have not done is do a High speed balance on my wheels. Thats about all i can think of. I really hope that will solve the problem but I have a bad feeling that is not the only issue.
-Kenji
Originally Posted by lexforlife
there is a slight vib around 70-75 on me to but very very slight.. i think altering the bushings has altered where the car reaches harmonics.. i def prefer it to be around 75 then 55-65 which is where we always tend to drive.. mine again is very very slight
My problem is exactly the same as your. Very slight vibrations at 70-75, which is a lot better than 55. But sometimes its a little bit more shaking depending on the weather I think. I just wish the problem would just be perfectly fixed, but then again nothing is perfect. Do you think its my wheels that need to be balanced still? Are yours perfectly balanced and still shaking at 70-75?
-Kenji
Originally Posted by rominl
yeah i would bet it's the wheel balancing as well.
do you have noise going up and down driveways? if not i think the ball joints are still ok
No noise or clicking sound anymore after installation. I really hope its just the wheal.
-kenji
I think its ur wheels/tires balancing. When i had my stock 17" wheels/tires on, my car would vibrate between 110-140KM/H . Now I have my winter 16" tires/wheels and no more vibrations at all. my car has almost 110,000 KM.
exclusive matchup
i just did some tests yesterday evening and this morning. i did various speed from 55mph, 60mph, 65mph, 70mph, and 75mph. i had no vibration at all (not even slight). i even let go of my steering wheel and looked at it and i didn't see it shake.
so hopefully it's just the wheels
