From Ltuned to coilover, help!!
hi guys im running on Ltuned suspension+ cusco rear STB and i love it, but i still want to eliminate the body roll, do u guys think if i change to coilovers like Tein CS or HA, the body roll will be eliminated even more, or how about the TRD sways??? which one should i look forward to????? need some help! thanks guys!
i think you should try the trd sways first, i think that helps body roll alot, then if you want a sportier ride and even more stiffer then get the tein-ha, imo tein-ha is a very good coilover system, but try the sways first, that may help alot
Definitely get the TRD Sways (and Lower Chassis Brace). It will help eliminate body roll more than the Ltuned Suspension and rear STB alone. Also get a Front STB (TRD, UGO, whatever).
Tein HA's ride pretty harsh IMO...if you go coilovers, you might want to consider the Tein CS's...it's Hardest setting is a little stiffer than the HA's softest setting. However, if you don't mind a stiff ride, the HA will work...
