Do I need another alignment?
My TRD STB, chassis brace and sway bars came in and are going to be installed by the dealer. The dealer said the alignment does not have to be re-done. Is the dealer correct? I learned to never assume the dealer is always correct. When I had my L-tuned spring/shocks done they did do an alignment.
Thanks,
the dealer is correct, changing those STB and sway does not change the alignment of your car, basicly just a swap in/out job, they don't adjust your sway bar to correct the suspension... you should be fine
The dealer is right. I had an alignment with springs/shocks, but not with my later sways, LCB install.
