front end making a "woowoowoowoo" sound
Im getting a loud woo woow woo sound on the freeway, im thinking its time to replace the wheel bearings. Could it be somethign else? Has anyone heard the same noise?
is bubb rubb under your hood?
http://www.ebaumsworld.com/bubbrubbflash.html
sorry, i had to
if it's a deep sounding woowoowoowoo it's probably just a tire or your alignment is off...bad wheel bearing while make more of a squeaking noise
sorry, i had to
they're about 10k miles in, im on yokohamas AVS. I just rotated the tires, didnt do too much to the sound, only makes it on freeway though.
So the wheel bearing sound is worse?
haha on the bubbrubb i let him out before i heard the woowoo!
i had the same soud with my bridgestones everytime they started to ware, might be that..i'd be on the phone with people and would just start to sing " Can you woo woo wooo?"
I have Yokahama AVS ES100 tires on my 95 SC4. I just picked up my car from the dealer today. I had a WooWooWoo sound coming from my rear - it showed up over the course of a couple days. The noise would go away on a hard left turn. It turns out it was my driver's side wheel bearing. I had it replaced along with the hub (the bearing must be pressed onto the hub) and the seals and labor set me back $700. Normally, I wrench on my car - but I lacked the press needed to install the new bearings. The parts alone are expensive. On my 95 SC4 the parts were:
Rear Wheel Bearing P/N 90369-43005-77 - List $114.78
Shaft Sub-Assy, RR (Hub) P/N 42301-30030 - List $188.97
Seal Type T Oil P/N 90311-63001 - List $20.39
Just for kicks and giggles I called the Toyota dealer as the rear on a SC is the same as the NA and TT Supra - They quoted me $400 but I doubt they factored in all the parts and labor required.
My advice - get it checked out by a mechanic you trust and go from there.
Shawn
Shawn
More than likely, it's the tires.
The AVS Sport is a nice sticky tire, but they get terribly noisy at about the mileage you have.
I have 'em on my GS in 20" and they make the same noise... mostly at about 40 mph or so- you can't hear them at freeway speeds.
arentz07
06-06-19 01:48 AM
pdx05470
11-27-10 10:52 AM
