need help what could it be (bad vibration in the front wheels at about 50 to 65)
Old 07-18-05, 07:44 AM
TRULUX
TRULUX's Avatar
Default need help what could it be (bad vibration in the front wheels at about 50 to 65)
i am getting pretty bad vibration in the front wheels at about 50 to 65. i put on new springs and shocks about two months ago. along with new ball joints and tie rod ends. the tires where just balanced along with a new alingment. could it be a bushing.
nate
Old 07-18-05, 09:34 PM
koolaidman
koolaidman's Avatar
nate
a bushing would make ur steering wander
Old 07-19-05, 07:02 AM
TRULUX
TRULUX's Avatar
My car feels like it is riding on rails. Drives straight like a aarow. The vibration at 55 to 65 makes the wheel shake pretty bad.
Old 07-19-05, 11:20 AM
lexforlife
lexforlife's Avatar
something i have noticed recently
if the wheel is not mounted perfectly on the hub and the lugs not trq using a start apttern and trqed equally i get the same problem
try taking the wheel off and remounting making sure its on the hub straight
Old 07-19-05, 08:00 PM
jonathancl
jonathancl's Avatar
Who mounted your tires? How aggressively have you driven since your tires were balanced?
The GS seems prone to vibrations caused by the tires actually changing position on the rim due to aggressive driving.
I suppose it's due to overuse of lubricant when mounting and the weight of the car...and how we drive.
Old 07-20-05, 06:32 AM
STONER
STONER's Avatar
I did this last night, and it seems to have worked. While on the ground, I loosened all the lugs and tightened them in five steps or so for each wheel; going through the star pattern. Each time a little bit tighter (don't tighten one lug all the way down and then go to the next). It feels much better than it did.
Old 07-20-05, 07:39 AM
TRULUX
TRULUX's Avatar
thank guys. i will try to remount them. i drive pretty aggressive. take the corners a little to fast sometimes. but its just too fun not too. if that does not work i will have them remounted and balanced
Loyalone72
09-24-22 08:37 AM
skassamali
09-21-11 09:29 PM
Yahoo27
SC- 1st Gen (1992-2000)
21
02-10-09 07:39 AM
durightman
04-17-03 08:12 AM
StylinGS300
03-13-03 01:53 PM
Quick Reply: need help what could it be (bad vibration in the front wheels at about 50 to 65)
