View Poll Results: What part of your suspension have camber issues after your drop?
More severe camber up front
28
41.79%
More severe camber in rear
16
23.88%
Both front and rear are equally severe
13.43%
I don't care....Im SLAMMED down...and that's all that matters!!
14
20.90%
Voters: 67. You may not vote on this poll
Poll: Camber issue for lowered rides
Old 07-15-05, 10:53 AM
PHML
Master Thread Closer!!
PHML's Avatar
Default Poll: Camber issue for lowered rides
OK....I know most of you have lowered / dropped ur GS....and many of you have some camber issues.
Regardless of your drop height.....where do you have the worse / most severe camber issues?
Old 07-15-05, 11:09 AM
TXGS
TXGS's Avatar
My Tein CS are adjusted approx 10-15 mm from the last thread. I'm only slighty outside the camber range on the left rear. No unusal tire wear yet. It's been like that for 3 months/5000 miles.
Old 07-15-05, 11:15 AM
BananaGS
Tech Guru
BananaGS's Avatar
1.3" drop, front tires wear faster on the inside, rear tire is wearing also (inside) but at a very slow rate(not really noticeable compare to the front), sorry i can't rotate my tire, but no biggie, the wear is pretty slow, probably have to change tire a few months faster that if you would normally with good camber
oh well, look better, drive better with the drop, a little of inside wearing also mean better handling too ha ha, more traction around the turn
Old 07-15-05, 11:21 AM
PHML
PHML's Avatar
Hey Anh...
Nice to see you back on the board!!
Pete
Old 07-15-05, 01:57 PM
rominl
exclusive matchup
rominl's Avatar
i think both my front and back are off, with the front more severe
Old 07-15-05, 04:46 PM
GS300Rich
GS300Rich's Avatar
I always get the most inside tire wear up front. The rear is usually pretty close to spec, so not much wear there.
Old 07-15-05, 07:26 PM
SoCalSC4
SoCalSC4's Avatar
Mine is dropped about 2" I guess. The most recent alignment revealed -1.8 degrees front & rear.
This is with the OE camber eccentric adjusters maxed-out to their most positive setting.
Suprisingly, the rear tires wear very evenly- the fronts get chewed up on the inside in a hurry.
Todd at TM Engineering and Fortune at Daizen and I have discussed this phenomenon; we belive it is toe-out related, from the "trailing" or "caster" arms bushings failing. This allows the front suspension to toe-out when the car is moving forward- even if you set the toe-in to OE specs, it will change when the car is in motion. This toe-out condition also causes a "darty" feeling at freeway speeds.
Daizen was working on a replacement bushing for this arm, as Lexus makes you purchase the entire new arm assembly. There have been issues with the bushing supplier... I broke down and bought the new control arms from the dealer. I'll install them this week (along with new lower ball joints) and give you all an updated report after the car is re-aligned!
Old 07-17-05, 11:53 AM
b1gredek
b1gredek's Avatar
for some reason when my car was slammed, the rear never wore out, but now i lifted it to uncut springs in the rear,,,,, the rear wears out faster now...... never understood why cause my rear cambered like crazy and the tires lasted me 30k miles.......... so for my vote as of today,the rear wears out faster than the front
Old 07-18-05, 04:24 PM
gawd
gawd's Avatar
My fronts are off as well, 1.3 degrees out of OE range. Rear are almost to spec with a 1.5" drop all around. Staggered set up, so no rotation for me either. Guess I'll have to find some cheap front tires
Old 07-18-05, 07:50 PM
jtanoyo1
jtanoyo1's Avatar
Just slam it pete, who cares about some lousy tires....
Old 07-20-05, 06:43 PM
PHML
PHML's Avatar
I cant afford to keep on buying tires....i know you can...but not me.
Old 08-08-05, 04:52 PM
joshoowa
joshoowa's Avatar
well i cant contribute much because i just recently installed my coilovers.. im hoping theres not much camber because im running a very conservative drop, 2 finger gap all around.
Old 08-08-05, 05:54 PM
GS300Rich
GS300Rich's Avatar
You shouldnt have a problem with 2 finger gap. When I was at 1 finger gap my camber was almost to spec
Old 08-09-05, 10:31 PM
Ex996
Ex996's Avatar
Todd at TMEngineering is installing the Tanabe NF-210's on Friday (1.3 inch drop in front and approx 1 inch in the rear). Anyone think this will cause a camber problem? Apparently no camber kit available. Stock 18" btw.
Old 08-21-05, 04:41 PM
TRULUX
TRULUX's Avatar
jic-magic asked what we want in the car chat. i think we need to all say something about the camber kit.the more the better chance we have of them making us one.
Quick Reply: Poll: Camber issue for lowered rides
