Tein CS Clank
Tein CS Clank
Ok, I know there have been a lot of threads about the Tein CS kit and the noises that it makes. I am getting a clanking noise out of my left rear. I have had the kit on about 2 months now. I am a little concerned that a kit that cost this much is making noises like it is. I am going to take the wheel off tom and take a gander and see if anything is loost. My question is, is anyone else experienceing a clanking noise?
Any input will be much appriciates.
Nick
Nick
https://www.clublexus.com/forums/sho...d.php?t=160794
Check out my thread here. I have a clank also on the front right side. There is a rubber piece that is at the top of the coilover under a nut and washer and on mine it totally disintegrated. The rubber shavings are still on top of the coilover. I have pics in the thread for you to look at. I talked to steve and gave him the pictures and he is talking to Tein to see what I need to do. If I need to send the coilover back in I will just buy a new coilover and send the damaged one in later. I hope all I need to do is replace the rubber piece and all will be good.
i suggest you go in the trunk and take out the lining and look at the rubber piece on the coilover and make sure that isnt the problem.
I only get the noise when I go over a bump or a pothole. Is that the same that you experience?
Ok, after a little inspection I found that the shop who installed my kit failed to torque down the top retaining nut on the strut rod. I find this to be absolutly rediculous. I am going to be at their door bright and early tom. morning to let them know about this. Since a simple task like this was not taken care of, I went throught the entire suspension and check and torque all bolts to specs. I mean seriously, how hard is it to read the instructions and torque down such an important nut.
-A very angry Nick
PS: GS3300Rich, you might want to check your top nut. If this nut is loost, I can see how it could destroy the rubber bushing on top.
-A very angry Nick
-A very angry Nick
-A very angry Nick
Thanks for the info Nick. I was wondering if that could be the culpret of my damage. When you torqued the nut down did you have to remove the edfc motor? I will hopefully hear about this rubber part and maybe I can order a new one. If that is the cause the shop that worked on this will definately be getting the repair bill
-Nick
Nick, could you pm those numbers to me? Or post them here. My tein manual is in the boxes which is in storage right now. Maybe I can just call up tein and order directly from them.
Rich
Rich
Tein type cs upper mount bushing
I recently got that problem where my rubber bushing gave up. I emailed tein but it seems like they don’t even know the part number. I sent them pictures and all and nothing I got a lower bushing replacement something I didn’t need. If you do know the part number or anyone know where I can get the replacement bushing please send the link.
Jbanuelos, You probably just need to order a whole new upper mount for that coilover.
