The Ball Joint Dilemma
Hello everyone,
I think I went through 5-6 threads in this forum about the best way to fix the LCA bushings. I am pretty confident now that the Supra 93.5 and up LCA are the best option because they are the cheapest, have beefier bushings, and come with a new ball joint.
However, my question is did anyone do the job himself? And if so how did you get the Ball Joint out because as I look at the suspension and check the Lexus manual that I have, the ball joint is the one part that I am not sure how to replace.
I would appreciate any input, and thanks in advance.
There is a special tool that you will need to separate the ball joint. You can rent or borrow one from a local auto parts store. Good luck on your project. You should do a write up of it so take lots of pics!
Yes I thought that would be a good idea, because I am sure there others who are thinking about doing the job to save money.
So your saying stores are willing to rent you this tool? and from there its a basic job?
Pickle forks are only used as a last resort, they can rip right through the rubber grease boots if not used and positioned just right. Trust me on the pit man arm puller I posted above, it easily seperated the front lower ball joints to allow me to install Daizen bushings.
like djl said use the picklefork as a lastresort it will most surely rip the balljoint boot. also you cant replace the balljoint seperatly on our lca's u need a new control arm. while your at it why dont u install dazian lca poly-bushings. i did mine in my garage in a day. i used a powersteering pully puller that i bought from autozone for 10 bucks. if you go to toyota.spx.com and type in 09628-62011 under the search bar u will find the tool they use at the dealership. (this is similar looking to what i used). the dazian bushing kit is around 90$ and has bushings for both front lca's and both front uca's. i bought mine from tm engineering.
It would be nice if someone made replacement rubber boots for the ball joints.
It's absolutely rediculous that you'd have to buy a $400 control arm because a 30 cent boot is torn.
Zombie Slayer
Thanks for the info djl!!!! I'll have to go out and get a pitman arm tool now, especially since it's only around $10.00
The best way I've found to remove ball joints is to rap the side of the spindle right next to the ball joint with a hammer, striking sideways.
It's the (annular)shock wave that pops it out, no need to touch the rubber boot.
Forget where I learned that trick, but it's how Belltech does it someone mentioned once.
Good Luck, and get the car aligned right away, or else bye bye tire tread(likely).
