stock shocks part number
couldn't find the info by search. i was cleaning up stuff and found all the stock shocks (gs400 and is300), and i was wondering which set is for the gs400
one set, it only says LL-23 and LL-24 (one for front and one for rear) on it, can't find anything else
on the other set, it says 48530-53090 DA-3 on one and the other says 48510-53030 DA-16. both are KYB.
anyone able to tell me which set is for the gs400? maybe someone can run and take a look at their stock 400 shocks thanks a bunch!
1 Post
Wow the "LEXUS GOD" needs an answer I'm shocked , Romil to the BATCAVE immediately. I just installed my HKS coilovers and took of the stocks if nobody replies to this thread by the time I get home from work I'll check for you and PM you.
I knew buying the 98-99 parts book would come in handy
Front: 48510-39695
Rear: 48530-39465
These are for both GS300 and GS400 according to the book. If you happen to be looking for a set, I should have some for sale within the next week. My L-Tuned springs/shocks should be here today
Front: 48510-39695
Rear: 48530-39465
Front: 48510-39695
Rear: 48530-39465
Front: 48510-39695
Rear: 48530-39465
ummm so now the problem..... the first 5 digits match up no problem, but the second 5 don't match up with the one i have (the one that i actually found numbers on). does that mean those are for the is300, and the ones that i can't find anything is for the gs400?
anyone knows how to break down the part number? i know the shocks are kyb, not sure if the part number is exclusive to toyota or same with kyb
man this is killing me @_@
oh thank you thank you thank you, that's awesome!
My LTuned setup came today, so if you don't have it figured in the next few days, let me know and I can look at my stock ones if I have them out. Heck, If i mix up my LTuned and stock one's i could be in trouble, these things have NO stamping on them whatsoever. The box didn't even say LTuned, but the one the springs came in had it everywhere???
There a white label on each one. I don't know what's front or rear so all I can say is:
on the longer shocks -- both labels have "063" then under the 063 is :
"00/08/28 2 0606" on one long shock
"00/08/28 2 0607" on the other long shock
The shorter shocks -- both labels have "062" then under the 062 is:
"00/10/09 1 1255" on one short shock
"00/10/09 1 1256" on the other short shock
thanks for all the help guys. after all the exhaustive search and comparisons, i think i found the answer.
the ones that say LL23 and LL24, those shouold be the GS shocks. the other two, after some serach, they belong to the is300.
it's so funny, on aftermarket parts you find info all over the internet. but on oem stuff, it's so hard to find info
thanks for all the help again guys, you guys are the best
