New toys for my SC4 for Christmas- pics
So my SC got some presents for christmas-
The first toy was a set of Daizen Adjustable Sway Bars from Todd at TM Engineering- I can't say anything about TM that hasn't already been said, but they are truley a pleasure to do business with. He went above in beyond as far as service goes, and was always able and willing to answer any questions I had. They impressed me and have my loyalty as a customer.- enough of that- heres a pic and a quick write up on the sways...
Daizen Sways!
These sway bars are a quite a bit larger than are stock sways... This is a mod that I have been wanting since I swapped out my original sway bar bushings for the poly urethane sway bar bushings. The Install is fairly simple... I did it by my self. That said, its not as easy as stealing candy from a baby- but its not brain surgery. The rear sway bars are three way adjustable, with three different holes for the end links to connect to. The different holes allow for different "feels" from the car ranging from understeer to oversteer. I set mine on the oversteer set up for the time being, just to feel it. The car now tracks like its on rails, and is predictable through out turns. I really like the feed back that I am now recieving through out turns and I have much more confidence when approaching sharp curves. I recomend them to anyone wanting to go a step further than the coilover/ spring strut upgrade.
New Air Compressor
If your a "do-it-yourself" guy like me, then you NEED air! I wll never turn a wrench for anything other than tightening again! Im tierd of the throbbing, swollen, cut fingers and hands! I now use this craftsman 150 psi, 6 HP Air Compressor with a 33 gallon tank. Along with my new compressor I have some new Air Tools!
If you haven't used air before, you have no idea what your missing! Give it a shot, and you will never again use your own strength to tighten that damn bolt thats going to give you that swollen and bleeding knuckle!
I used the new tools to aid me in my swaybar install today and it went fairly flawlessly. The toughest part of the install was the removal and installation of the front swaybar. other than that, it was all removing bolts and tightening bolts. (*note*- to get the rear sway bar out and new rear in I took my JIC exhaust off the two rear most hangers and let it hang slightly down so I could slide the swaybars in or out.)
Hope everyone else car had a merry christmas- I know mine has- and mine is looking forward to carving pavement as it adjust to its new stiffer sways!
Daizen Sways!
New Air Compressor
There are downsides to living in San Francisco.
I guess Santa is pretty busy around here and forgets even the "nice" kids.
Better keep his lousy raindeer off the roads....I'm not wasting my brakes. j/k
Our garage is pathetic. My SC doesn't even fit in it lenghtwise unless I block a door that we use pretty often.
There is little room for a floorjack, much less a 33 gallon air tank.
Glad you like your new toys.
Originally Posted by /Aerostar\
NICE, looks just like my air compressor. You're goin to love air tools, but a little advise: Get the shortest hose you can for your needs, the shorter the hose, the power you'll get.
As far as TM's website- go to www.tmengineering.net - very classy shop to deal with!
how does it feel now,... did you already have it lowered and bushings replaced?? I've done everything except the sway bars,... might do that next,... but somehow, I'm thinkin' it's SAFC II, intake, and exhaust time.... ( haven't touched the car engine wise yet )...
