View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 03-28-16, 08:16 AM
  #406
PandaGS300
PandaGS300's Avatar
Originally Posted by hcharlesc3
How does the center of the rotor sit on on the hub?
Sits flush, where is no play with the bore. just between the studs where is play.
Cant figure out why, according to brembo these are meant for a LS400
Old 03-29-16, 09:12 PM
  #407
lexo98
lexo98's Avatar
How much play are you talking about. There is always some play.
Old 04-05-16, 02:42 PM
  #408
PandaGS300
PandaGS300's Avatar
A little bit of play nothing too crazy but there is some play.
Also there is no way a 5mm or 10mm spacer wont fit stock rims.
I can't see anything less then extended studs and a 15mm spacer atleast fitting stock rims.
Old 04-17-16, 01:36 PM
  #409
GS400V8
GS400V8's Avatar
Thanks to everyone whos went through all the trial and error to see what was needed to make this work! I really like the idea of having fixed calipers on all four corners for a total of 12 pistons!
It looks like 18mm is the minimum RCA height. I really like the 2007 3GS 18" 5 Spoke Chrome wheels. If I do this I'd probably paint the calipers gloss black.
Old 06-12-16, 07:31 PM
  #410
AlphaOnion
AlphaOnion's Avatar
Does anyone know about rear calipers and rotors? For instance, are LS400 rear calipers and rotors a direct swap onto the 2GS? Is it possible to put the stock 2GS front calipers onto the rear? I'm just looking to replace the stock rear calipers when I do the fronts, since they're ugly and made of iron as opposed to the LS aluminum calipers.
Old 06-13-16, 09:36 AM
  #411
sakataj
sakataj's Avatar
SEARCH..... no point in doing them
Old 01-02-17, 08:42 AM
  #412
moby15
moby15's Avatar
Originally Posted by gr8bryt
I got my calipers and pads from AutoZone, I think I got the rotors from Summit Racing (they're EBC brand, so anywhere that sells them should be ok), and I used OEM brake lines. After reading through this whole thread a few times, I didn't see any benefit to upgrading them for everyday driving purposes. My car has less than 60K on it so they were still in good shape. I purchased extended wheel studs and spacers from a local shop. I believe I needed .25" or .5" spacers. I was on a budget and the studs and spacers were an expense unaccounted for. I only had enough to do the front wheels. As a result, my front wheels stick out a little further than the rears. It doesn't affect handling or wear too bad. I'm not too savvy when it comes to DIY so I had everything installed at the dealership that I work at. Here's a few pics, hope this helps. Best wishes!
hi, just wondering if you have used factory 16 inch rims, as im doing the same upgrade,
thanks
Old 01-10-17, 07:05 AM
  #413
gr8bryt
gr8bryt's Avatar
Yes, factory 16" wheels fit w/ aforementioned .5" spacers.
Old 01-10-17, 07:58 AM
  #414
gr8bryt
gr8bryt's Avatar
Here's a closer look. Be sure to get hub centric spacers to avoid vibration during highway speeds.
The following 2 users liked this post by gr8bryt:
GSpearlwht (06-10-19), moby15 (01-16-17)
Old 01-16-17, 12:45 AM
  #415
moby15
moby15's Avatar
[QUOTE=gr8bryt;9732453]Here's a closer look. Be sure to get hub centric spacers to avoid vibration during highway speeds.
cheers for your help, now i can carry on with the install.
thanks
Old 02-16-17, 08:58 PM
  #416
sladkix
sladkix's Avatar
Originally Posted by robbaric
I have 93 toyota supra tt calipers and rotors
Attachment 321801
Attachment 321802
​​​​​​​did you have to use spacers?
Old 02-27-17, 07:47 AM
  #417
ZanderZ32
ZanderZ32's Avatar
Ill be installing the LS calipers with my gs460 wheels later this week. I think my 15mm H&R spacers will be enough for clearance.
Old 05-21-17, 09:27 PM
  #418
RamAirRckt
RamAirRckt's Avatar
Just picked up some IS250 17" wheels, hoping they will clear the LS or Supra calipers....
Old 06-10-19, 09:21 PM
  #419
GSpearlwht
GSpearlwht's Avatar
Nice!! So i want to add caliper cover to my brakes, do i need spacers? I dont know what the spacers for.
Old 02-17-20, 12:23 PM
  #420
n1ck
n1ck's Avatar
Finished the LS conversion a couple weeks ago. IS 18s fit perfect with no spacer.
The following 2 users liked this post by n1ck:
AirRideFan (03-02-20), SharifM (03-23-20)
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
