Mild but great brake upgrade
Old 12-11-04, 04:00 PM
Received 2,127 Likes on 1,379 Posts
Thumbs up Mild but great brake upgrade
I've had the StopTech front big brake package on my car for a while with the stock rear brakes. Great setup, but the Axxis Ultimate brake pads that came with the StopTechs were driving me nuts for 2 reasons: 1) They would squeak when coming to a slow stop after the brakes had warmed up, i.e., after 2 minutes of driving!, and 2) they put off MASSIVE amounts of dust and made my nice HREs FILTHY within a couple of days of the light amount of driving I do.
So today I had the Ultimate front pads replaced with the milder Axxis MetalMasters, and I also had the rear stock components except the caliper replaced, including new Brembo drilled (stock size) rotors, MetalMaster pads, and steel brake lines.
So far I'm THRILLED with the results. Braking is still VERY potent but more smoothly controllable. The setup before with the front Ultimates and stock rear pads was rather 'grabby', PLUS, the Ultimates have a disconcerting quality in rain where they 'slide' over the rotors (lessening braking capability) until warmed up.
Hopefully these pads will be less dusty than the old Ultimates too!
On a negative note I will say I'm underwhelmed by the cosmetic improvement of the drilled Brembo rear rotors which I got to look better with the drilled front StopTechs. The rears don't have many holes plus being stock sized they still look too small. Oh well, still marginally better than stock.
Old 12-11-04, 09:44 PM
redgs4
redgs4's Avatar
The metal masters are a big improvement over the ultimates, IMO. Way, way, way, way less dust and just a little squeaking/screeching.
I think your brembo rotors looks pretty good. Don't quite fill out those nice HRE's, though. I guess size does matter.
Old 12-12-04, 02:28 AM
Neo
The One
Neo's Avatar
Nice Bit. Any reason why you did not go with the rotors from StopTech?
And you, stop showing off.
Old 12-12-04, 05:12 AM
Hameed
EV ftw!!!
Hameed's Avatar
About time you installed those parts that were sitting in your garage for about a year!
When I did my brake upgrade in April this year to the StopTech BBK, I did everything else at the same time - steel braided brake lines at the rear as well as the StopTech OEM size drilled rotors at the rear. I also did the Axxis MetalMasters pads in the front and I am still VERY HAPPY with them! No sqeaking at all and virtually zero brake dust.
What is driving me nuts though is the band of rust on the inner edge of the rotor surface - on both the front and rear rotors. It just kills the overall look of the HRE's and big brakes in the front.
Old 12-12-04, 06:56 AM
Thanks. Honestly I didn't know StopTech offered them when I bought the Brembos. It might have been nice to get those plastic (or whatever) black centers like the StopTechs, but no biggie - it's done now and I'm satisfied.
Hameed - I still honestly haven't seen that rust band on mine that you speak of, even when my wheels are clean. That must be near the center black part right, where the pads don't touch?
Old 12-12-04, 07:11 AM
Hameed
EV ftw!!!
Hameed's Avatar
Yes, exactly. Your rotors cannot be the same type I have if no rust is showing on yours.
Old 12-12-04, 11:29 AM
I took a closer look.and yes there's a rust 'band' - I usually can't see it in my garage because it's too dark by the rims. So don't worry, we have the same rotors.
Why don't you just paint the band black with a rustproofing type of paint like Rustoleum?
Old 12-13-04, 03:09 AM
rominl
exclusive matchup
rominl's Avatar
haha man, i can never notice that rust.... come on guys, don't be picky!
Old 12-13-04, 04:51 AM
Hameed
EV ftw!!!
Hameed's Avatar
Of course you can't! You have the same "less open look" wheels that Bit has! If your wheels were like mine which are "very open", trust me, it would bother you a lot! I intend to do something about it pretty soon.
Old 12-13-04, 06:29 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Thanks for the writeup! Bit, just curious.... did you do any bedding on the rear brakes?
I've never really thought about how to approach it when you do just rear.
Old 12-13-04, 06:54 AM
SC400-V8
SC400-V8's Avatar
I wanted to get the basic non-drilled, non-slotted brembo rotors when I have a brake-job done in a year... I was told that they may squeek or squeel because the OEM rotors are softer and quieter, is there much truth to this?
I would love to keep the OEM setup, but dropping over 500 bucks on rotors is NOT on my list of priorities.
Old 12-13-04, 07:18 AM
Well I did front pads as well as rear, so VVT-i did do the 'bedding' drive before I got the car back.
Old 12-13-04, 09:59 AM
rominl
exclusive matchup
rominl's Avatar
hahhaa, well, that might be the reason why you should just get some other hre wheels? *cough bob cough*
Old 12-13-04, 10:00 AM
rominl
exclusive matchup
rominl's Avatar
umm, i think it depends on the pads too. after all those are the two stuff rubbing with each other. if you get brembo blanks (which imho are stronger than stock) and some nice pads that's not max performance, then you should be fine
Old 12-13-04, 11:00 AM
Hameed
EV ftw!!!
Hameed's Avatar
When you open your Bank that you mentioned sometime ago, I will be your first client for a loan and then I can get Bob's wheels.
Quick Reply: Mild but great brake upgrade
