Guys i put on my 19's wheels and my car is dropped with Tein CS. I recently did alignment on my car. But now i want to drop my car about a quarter inch on the right passenger side. The right side seems to be 1/4 higher than my left side. I was wondering how much thread i should drop to get the right side even with the left side and after lowering will my alignment be significantly off and if i need to redo alignment or not. Please Help!!!
ah tommy, you shouldn't do alignment before you get the height you want. and yeah, you need to drop the car different on all 4 corners to just get the right height all around. you probably need to do that and then get alignmnent again
Tommy, I would say 3-4 threads should be about right. Just remember after adjusting the threads to drive your car around the block to allow everything to settle. Then check your height again... I had the same problem you did...
Thanks Ken. I think i'll leave my drop as it is right now. I just did alignment 2 weeks ago.. I dont want my alignment and camber to be off. Tires is HELLA Expensive =(
Originally posted by suxel003sg can you post the contact for the Specialty suspension shop. i am in the la area and wondering if it is near by, thanks, suxel
If you are talking about the one rominl and I go to, it is in Norcal. Probably too far a drive.
