Need help with brakes
I got some new mods installed today and with it some problems. I will post pics of all the new mods on the other section. I got a set of HKS LS+ Rotora bigbrake kit and new rotors and SS lines for the rear. My problem is that when you have the car off and you first get in it when you hit the brake to put it in gear the brake pedals goes almost all the way to floor and makes a loud psssst noise. After the first noise it gets quiet. Then when your riding around and you put the brake down at a complete stop you can feel the pads het the rotor then if you keep pressing the brake you can push the pedal all the way to the floor. My installer bleed the front and rear. But I think he did it weird. He did the Rear right then the front left than the rear left than the front left. I need your help. Im going back to him tomorrow to adjust the height and I need to tell him what to do to fix it. Thanks in advance.
He also had the car off with the key in my pocket. So should he have the car running or just with the key in the on position? Then bleed it like you said rear right rear left front right front left? Thanks.
So if I rebleed it all correctly it should be fine right? Should I have the car running or with it in the on position then follow the correct pattern. That should fix it right?
exclusive matchup
Car must be on acc. or running to do the bleed. Sounds like this guy doesn't know what he's doing.
On my big brake upgrade we had to bleed them twice, so hang in there.
Thanks guys for all your help. Well there was air stil in my lines and it was all my fault. He did bleed the brakes the correct pattern but the car was off. I was in the driver seat pumping the peddle. I was in there for some time b4 we started. So i got tired of hearing the radio and took the key out and out it in my pocket. The car was in the acc postion. He never knew I took the key out and I never mentiond anything about the key till i brought the car back. He told me i was a a$$hole. We bleed the brakes again with it running this time. Everything was much much better. The braking was way better than stock. Im waitng on the coilovers to settle so we can adjust. The front has a 1 finger gap. The rear is dumped. I will post some pics after i get the resized. There all abot 2 megs in size.
Excellent - really glad it worked out. Also glad to hear your shop's only problem was with the 'volunteer help'.
