Thump noise w/ Daizen Sways?
Old 02-18-04, 05:56 AM
CokeBear
CokeBear's Avatar
Unhappy Thump noise w/ Daizen Sways?
I recently installed the Daizen Sway. I have been very happy with the performance. The car corners a lot flatter and the over all handling is significantly improved.
This morning while driving to work, I noticed a thump noise in the front whenever one of the front wheels goes over a bump. Any one have any idea what's causing that noise?
Thanks,
Marc.
Old 02-18-04, 06:30 AM
Letsride
Letsride's Avatar
Check the bolts that are holding the bars...see if they are tight!
Old 02-18-04, 09:30 AM
rominl
exclusive matchup
rominl's Avatar
yeah check if they are all tightened down right, and on the other hand i think you can't tighten them too much?
Old 02-18-04, 10:36 AM
lexforlife
lexforlife's Avatar
trq front bolts no more then 18lbs also check the 4 bolts that mount the sway bar brackets to the bottom of the engine cradle , make sure the 2 bolts on either side for the end likes are tight
Old 02-18-04, 04:01 PM
CokeBear
CokeBear's Avatar
thanks for the advise. I will put the car on the ramps this weekend and check it out. I hope its not something serious.
Old 02-18-04, 04:39 PM
FutureGS400
FutureGS400's Avatar
Exclamation Don 't wait...
I wouldn't wait for the weekend to check it if I were you. If there were loose bolts and the sway bar actually came loose while driving... Not worth the risk!
koreywill
14
10-10-17 03:30 AM
hlee1169
11-29-06 02:21 AM
GS300t
Suspension and Brakes
20
05-10-06 05:49 PM
Threxx
12
11-12-05 08:07 PM
PHML
12-06-04 08:38 AM
Quick Reply: Thump noise w/ Daizen Sways?
