Adjusting Your Teins
Here is what Tein wrote to me on adjusting your Teins. Thought I would start a new thread so when people search, it would be more apparent to them.
Here is what they wrote:
Please let me explain to you about the damping force adjustment of our dampers. With SS dampers, you can adjust its damping forces at 16 different levels. To make it the hardest setting, turn the **** clockwise until it stops. Then, turn it the other way around to make it softer.
Full stiff
Using the included wrench (Hex wrench) to turn the adjustment **** on the top of the position rod (shock shaft) to the hardest setting which is full clock wise (turning right). When you are finished setting the **** full clock wise you are set at 0.
Full soft
After you are set at full stiff which is 0 turn the adjustment **** counter clock wise (turning left) 16 level backwards. Please DO NOT pass the 16th level it will damage the damper.
Caution
USE ONLY LEVELS 1-16. Exceeding level 16 may cause damage to the damper.
DO NOT turn know past the last position. Turning the **** past its limit will result in damage to the damper.
Best regards,
Sales
Staff @ TEIN USA INC.
9798 Firestone Blvd.
Downey, CA 90241
Phone: (562)861-9161
Fax: (562)861-9171
www.tein.com
Full stiff
Full soft
Caution
Best regards,
Sales
Downey, CA 90241
Fax: (562)861-9171
www.tein.com
The One
Originally posted by mcgong
32 way adjustment.....can you clarify that for me? How does that work. Are there .5 adjustments.
